Do I need an LT1 starter when swapping to T56 ???
Old Sep 6, 2001 | 09:35 AM
RED92's Avatar
Do I need an LT1 starter when swapping to T56 from a T5? Will the LT1 strarter just bolt up to our engines?
Thanks...Alex
Old Sep 6, 2001 | 10:42 AM
SLAYER6669's Avatar
Car: 1991 Camaro Z28
Transmission: T56 6-Speed
As far as I know you do not, if you have an auto you have to modify a cover or something on the trannie beacuse the starter is larger in size and it wont fit correctly, but other than that I'm pretty positive you don't need a new starter especially since your a manual already..
1991 Camaro Z28
CURRENT MODS:
350 TPI, Automatic, Edelbrock Headers, Edelbrock Runners, Edelbrock Intake, Flowmaster Exhaust, MSD 8.5mm wires, Autolite Double Platinum Plugs, MSD Cap/Rotar, Random Technology high flow cat, Hypertech Power Chip (160 Deg Thermo), K&N Filterchargers
STEREO MODS:
Pioneer DEH-P6000, 2 JL Audio 12W3 subwoofers in custom hatch enclosure,
Rockford BD1000.1 Amp, Infinity Kappa 4x6" plates & 6x9's
WEBMASTER: www.thirdgenfbodies.com
Old Sep 6, 2001 | 10:44 AM
Steve91Z28 L98's Avatar
If you want to reuse the old style starter, you'll have to do a little bit of grinding on the bellhousing to allow the nose of the starter to fit. I went ahead and got the LT1 starter from the car I got the transmission out of. It's smaller (weighs a lot less) and I think it has a higher torque output than the standard starter.
1991 Z28 - 350 TPI, T56, McLeod street clutch, LT4 pressure plate, Pro 5.0 shifter, ported plenum & runners, AFPR, Hooker shorty headers w/o AIR, Flowmaster muffler, homeade ram-air, SSM subframe connectors, Kenny Brown STB, Global West steering box brace, Steve Spohn adjustable torque arm and T56 crossmember
Old Sep 6, 2001 | 10:46 AM
Keep in mind that I had an automatic before I did the swap. I'm not sure if the starters are different or not.
Old Sep 8, 2001 | 04:54 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Manual and automatic starters are different, the automatic one is larger, so it wont fit. You need a starter for a manual car.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
1984HO
Mar 19, 2021 11:59 AM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
rsrmoore
Aug 7, 2015 08:44 PM
