How much power could this axle handle?
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I just bought an axle for my car and was wondering if anybody could give me an idea of how much power it should be able to hold up against. It is a GM 10 bolt rear, with an Auburn Pro Posi unit, Precision Performance ring and pinion gears, Moser axles, and a stud gurdle cover. Any guesses?
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Re: How much power could this axle handle?
That's a heavily weighted question. It should be fine for your car with the mods listed in your sig. I wouldn't want it behind a 383 on slicks. Traction is what kills rears, not power. On a normal street car the tires will light up long before the rear will break. If your WC T5 is stock don't powershift it or it will break too.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
All the goodies including the aftermarket axle will help but the tiny ring and pinion is always the weakest part of the diff.
Cars have broken the teeth off on the street and others have survived 11 second passes on the track with no problems. You're rolling the dice as to how much power it can take.
ambainb
Apr 25, 2016 09:21 PM
red90IROCls1
Aug 25, 2015 06:56 AM
sailtexas186548
Aug 24, 2015 10:11 PM
