Clutch fork questions
Old May 29, 2009 | 06:54 AM
Unholy 89's Avatar
Car: '89 5spd GTA
Engine: 305(LB9) TPI
Axle/Gears: Borg-Warner 3.42
Can I remove and replace my clutch fork without removing the tranny?
Need to make sure the clip is on the throwout bearing correctly
Old May 29, 2009 | 07:45 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Re: Clutch fork questions
No. The fork installs from inside the bellhousing. You have to pull the tranas and bellhousing.
Old May 29, 2009 | 08:25 AM
Unholy 89's Avatar
Car: '89 5spd GTA
Thanks TKO,
I believe my fork / clip is installed worng and need to correct. I was just looking for a quick way to fix. I think I should be able to correct by just sliding the tranny back and leaving the bellhousing on. Sound right?
Old May 29, 2009 | 09:18 AM
Yeah, you should be able to. You'll have access inside through the trans bore.
Old Jun 1, 2009 | 06:55 AM
Unholy 89's Avatar
Car: '89 5spd GTA
Clutch is DONE!!!! Perfect feel....just as I thought, the a$$hole before had the fork incorrectly installed on the throwout bearing. 4 hours including the time to get her up in the air....I'm feeling pretty good.
Old Aug 31, 2009 | 10:32 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Did he have the throwout bearing on backwards or it wasn't fully on the fork?
Old Aug 31, 2009 | 11:40 PM
Unholy 89's Avatar
Car: '89 5spd GTA
Had the retaining clips on the outside of the bearing...supposed to be in the inside bearing race.
Old Sep 1, 2009 | 03:13 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Yes you can. But it will tweak and ruin the clip most times. And it's a major PITA to get it back on.
So no.
Old Sep 1, 2009 | 07:23 AM
Unholy 89's Avatar
Car: '89 5spd GTA
Mines already fixed...pulled the tranny to fix it.
Ghettobird52
Apr 21, 2020 08:44 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
rsrmoore
Aug 7, 2015 08:44 PM
