regearing
Old May 30, 2009 | 11:24 AM
Chezoom's Avatar
Car: 91 RS Vert, 87 SC T-Top
Engine: LO3, LG4
Transmission: 700r4's
Axle/Gears: 2.73, not sure yet
regearing
im going from a 2.73 peg leg to a 3.23 limited slip, i know the speedo will be off, so how do i fix this?
Old May 30, 2009 | 12:54 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: regearing
the easiest way is to just post your rear tire size and I'll post what you need.
Old May 30, 2009 | 03:45 PM
Chezoom's Avatar
Engine: LO3, LG4
Re: regearing
16 245 50
Old May 30, 2009 | 04:04 PM
StringRust's Avatar
Car: '89 Camaro Rs/ '87 Z28
Engine: 305 c.i. TBI/ 305 c.i. 4bbl
Transmission: 700r4/T5
Axle/Gears: 3.73 posi/ 3.73 posi
Re: regearing
Originally Posted by Chezoom
16 245 50
grey speedo gear?
edit: nevermind your talking 3.23 i think grey is for 3.73. dont listen to me.
Old May 30, 2009 | 04:05 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: regearing
You have 2 choices: (1) a gray 15 tooth drive gear, GM part number 8642620, and a blue 38 tooth driven gear, part number 25513045, or (2) a red 17 tooth drive gear, 8640517, with a purple 43 tooth driven gear, 25513050. You won't need to buy anything else to get the speedometer correct.
Old May 30, 2009 | 04:19 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: regearing
that was pretty fast atilla. is there a place to look because i have the same 3.72 stock but i went to 275/60 15 tires. i know 60 spedo is 65 actual but it would be good to have it right.
Old May 30, 2009 | 05:23 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: regearing
I'm working with a moderator on getting all this info I have, made into a sticky, on 700R-4 speedometer gears. But until then, What I need to know is rear tire size and rear axle ratio. In Tony's case, 3.72:1 gears don't exist, so he must have mis-typed.
Old May 30, 2009 | 06:59 PM
Chezoom's Avatar
Engine: LO3, LG4
Re: regearing
whats the difference between them, is this stuff exspencive?
Old May 31, 2009 | 10:37 AM
StringRust's Avatar
Re: regearing
I believe he meant 3.27 as he typed in first thread.
Old May 31, 2009 | 10:39 AM
StringRust's Avatar
Re: regearing
They aren't that expensive. Few bucks, maybe 15-20 if I recall when I got mine. I ordered mine through NAPA so they are easy to get as well. Maybe check NAPAs website for prices.
cycleguy04
Mar 27, 2014 12:19 AM
89rs358
Feb 20, 2011 10:17 AM
codemonkey
Dec 17, 2007 07:06 AM
LT4Hawk9
Jan 27, 2007 06:34 AM
87blueracr
Jun 7, 2005 01:29 PM
