Stuck 5th and "double-clutching" into 4th?
Old Sep 15, 2001 | 01:40 AM
DuffMan's Avatar
Car: '99 Cobra
Engine: 4.6 DOHC 32V
Transmission: T-45
Axle/Gears: 4.10
Well there are the symptoms. When I go into 4th, i have to shift to neutral, then back to 3rd, then let the rpms drop to shift into 4th. ALso, occasionally 5th gets stuck in gear. Reverse is also a bitch to, I shift into 4th (well actually into 3rd, then 4th) then into reverse. I am hoping its the tranny fluid, or actually the lack thereof :P
Any ideas if this doesnt help matters? Thanks a lot in advance!
1987 Camaro IROC-Z/Z28
305 TPI - 5-speed
Full Competition Kenwood System
Duff Man says, "Oh Yea!"
Old Sep 15, 2001 | 11:13 AM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
Sounds like your synchros are screwed. You might also have a bent shift fork. GET IT CHECKED AND REBUILT.
If the car is grinding heavily when you try to put the trans in reverse, either the clutch isnt fully releasing or you pilot bushing is shot. More than likely, the clutch isnt fully releasing. HAVE YOUR CLUTCH MASTER CYLINDER AND SLAVE CYLINDER CHECKED FOR LEAKS AND HAVE IT BLED.
Hope this helps.
[This message has been edited by JAYDUBB (edited September 15, 2001).]
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
tmellott89
Oct 14, 2015 02:06 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Dragonsys
Sep 25, 2015 03:51 PM
