3-4 upshift
Old Jul 7, 2001 | 11:44 PM
86_327_camaro's Avatar
3-4 upshift
i searched through the old posts and found a few part #'s for the 3-4 upshift valve. what i found was 8673948 which i know is supposed to be the upshift valve and the .500 boost valve. i also found 8639164 and 8634940 which are listed as a spring and a boost valve. in another post the contents of 8673948 are listed and it includes a spring and a boost valve. what i need to know is if those 2 extra parts are included in 8673948.
Old Jul 8, 2001 | 04:40 PM
anyone?
Old Jul 8, 2001 | 05:50 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I believe all you need is the upshift valve, the boost valve .500 controls the line pressure at making it higher to firm up shifts, it has nothing to do with being in OD at high speeds.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter
Soon to be installed
3:73 Richmond Gears and 3" Exhaust
"There is nothing more addicting than speed"
Old Jul 8, 2001 | 11:04 PM
jaymz's Avatar
In the kit pn 8673948 I received a pan gasket,two valvebody gaskets, one .475 boost valve w/ bushing set and a 3-4 tv bushing w/ valve. The .500 boost valve is a aftermarket part.Hope this helps.
Old Sep 15, 2001 | 07:16 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
<font face="Verdana, Arial" size="2">Originally posted by jaymz:
In the kit pn 8673948 I received a pan gasket,two valvebody gaskets, one .475 boost valve w/ bushing set and a 3-4 tv bushing w/ valve. The .500 boost valve is a aftermarket part.Hope this helps.</font>
Does anyone know what year the gaskets are from. Are they prior to 87 or after? I have an '86 therefore don't have an aux valvebody. Will I need a gasket set or can I use the ones included?
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Sep 16, 2001 | 12:14 AM
86_Dan_Z28's Avatar
Car: 86 Z28
It is a .422 boost valve, not .475.
devilschariot
Feb 25, 2016 03:08 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
6998poncho
Sep 25, 2015 02:56 PM
HikoriYami
Sep 21, 2015 07:11 PM
