Gear Swap Question
Old Sep 15, 2001 | 09:41 PM
CamaroRS's Avatar
Gear Swap Question
I have an 85 disc rearend with limited slip. The gears in it right now are 3.23, but I would like to change them to 3.42. I have located a 3.42 gear set from an 89 V6 RS and was wondering if I could swap it in. If so, is the process pretty easy? Any info would be appreciated. aTdHvAaNnKcSe
Old Sep 16, 2001 | 06:21 AM
ede's Avatar
ede
they both should fit your carried. it isn't to hard to change gears but does require working with some small and precise measuremants and using tools most people don't have (2-3 depth mike, 0-1 mike, dial indicator and mag base, dial type in/lbs torque wrench).
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
InfinityShade
Aug 22, 2015 08:00 PM
ezobens
Aug 19, 2015 10:29 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
mizz0313
Aug 12, 2015 06:45 AM
