7.5" or 7.65"????
7.5" or 7.65"????
I have found out that I have a GM 10 bolt rearend with a 3.08 gear and 26 spline axles and now i just need to know what the ring gear diameter i know that it is either 7.5 or 7.65. I would take it apart to find out but it is a daily driver and dont have the time. Any info would be great...it there is any indicators just let me know. The car is an 88 IROC with a five speed. just let me know
i thought all irocs were 9 bolts? why do you need to know the ring gear size? for a replacement gear set? they're the same part for 7.5 or 7.62 ring gears as long as it's a 10 bolt and you buy the correct gear for a 10 bolt you'll be fine. if you look at a catalog you'll notice it says for a x:xx numerical ration and higher and another gear set for x:xx numerical ration and lower. the ratio is about all you need to know.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The 7 1/2" ring and pinion are interchangable with 7 5/8" gears. They'll both use the same carrier.
If it's really a 9 bolt then you need 7 3/4" gears and won't find them in any real catalog listings.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.586
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
<font face="Verdana, Arial" size="2">If it's really a 9 bolt then you need 7 3/4" gears and won't find them in any real catalog listings.</font>
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
Currently installing 3.73's into my 9 bolt (YES, it is a 9 bolt & YES they are 3.73's, not 3.70. I currently have 4.10 gear sets and new series 3 carriers in stock for 9 bolts
)www.koolmeister.com
Yes, some IROCs did come with the 7.625" 10 bolt, but most had the 7.75" borg warner rears. But I think 7.5 and 7.625 parts can be used interchangeably.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Accel High Flow TPI Baseplate, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, Jet TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
L98 TPI 350 (5.7L)
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Only the 87-89 IROC's with 305 TPI 5-speed with G92, and the 350 L98's are 9-bolts. 305 TPI automatics from 85-92 are all 10-bolts.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Car: 89 Camaro RS
Engine: 305 TBI
Hey Kevin91z, would my 89rs be a 9 or 10 bolt? does that have any relation to the number of screws holding the cover on the diff? Thanks
89 RS Camaro, LO3 305 TBI
Autometer Air/Fuel Ratio Guage
Cooling Fan Overide Switch
L69 Duel Snorkel Intake
Dynomax Ultra Flo SS Cat Back
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
"305 TPI automatics from 85-92 are all 10-bolts."
Try and tell that to my 2.77 BW 9 bolt.
86 T/A 5.0 A4 & 2.77 gear
15.62 @ 86 mph
93 Civic 1.6L
13.5 @ 100 mph
15.62 @ 86 mph
93 Civic 1.6L
13.5 @ 100 mph
i have the 10 bolt in my 89 iroc.
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons,Hooker Comp headers, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 24lb SVO injectors, crane AFPR, all going through 3 inch mandrel pipe and a flowmaster.
New project-89 IROC-305 5spd...Jamex Springs...and thats just about it!Soon- 6 speed, Pro 5.0 shifter and 4.10's
http://users.argolink.net/bvana
http://ScreaminDeamin.cz28.com
Brandon
T/A's went to 9-bolt in 86
Camaros went in 87
All models lower then IROC/Z28 or not having G92 5L or 350 will have a 10-bolt
7.5" was 82-86 (I think)
7.65" was 87-92 and on I believe
you probably have a 10-bolt 7.65"
1989 Trans Am GTA, L98 5.7L TPI, TH700-R4, T-Tops, dual cats, 9-bolt rear, 3.27, Dynomax muffler, K&N
1992 Camaro RS, LO3 5.0L TBI, T-5, T-Tops, 3.08, L69 Dual Snorkel, K&N - Sold
Honda engines ROCK, I have one on my lawn mower but I still have to push it.
Camaros went in 87
ambainb
Apr 25, 2016 09:21 PM
Numbah-1
Sep 12, 2015 08:57 PM
