700R-4 downshift kit
Old Sep 18, 2001 | 10:27 PM
i roc k's Avatar
B&M sells a downshift kit to help so that your tranny doesnt downshift into third when in fourth at part throttle? Did anyone buy this and does it work very well and how do you install it? Please somone awnser this BOWTIE 4 life
Old Sep 19, 2001 | 03:36 AM
transfixleo's Avatar
That doesn't always give the desired response. Go with GM #8673948.
Old Sep 19, 2001 | 09:23 AM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
I just installed the GM kit and I like the results. I even posted the results here in this section(topic). The GM one will still allow a downshift to third at lower speeds but at highway speeds it stays in fourth unless you manually downshift it to third. I actually have 4 gears that I can use whenever I want to!
383 86 Camaro Z28 ---1/4 mile et>13.65@103mph,,
10.5:1compression Dart Pro 1 Aluminum heads 215cc>2.05/1.60 valves,400 steel crank,cam specs:224/234 at 050 525/525 lift,3500 stall converter,shift kit,4.10 gears,770 Holley Avenger,Victor Jr. Intake,true dual exh,Hooker headers with 40 series Flowmasters,MSD Coil and Module.ALSO SECOND GEN Z28---mods:454 BBC,.546 max lift(doug herbert cam ) 750 Holley vac sec. ,Edelbrock Performer manifold,Holley electric fuel pump,Hooker headers,Flowmaster mufflers,beefed up 700r4 tranny, 3.90 gears, powertrax unit, B&M console shifter.
Old Sep 19, 2001 | 09:24 AM
Car: 86 z28
By the way the B&M one is not worth your 35$!
Old Sep 19, 2001 | 11:45 PM
Ovrclck350's Avatar
I have one in my trunk that I'd give up for $10 + shipping
Email me tho if intersted, I don't post/check on this board often.
[This message has been edited by Ovrclck350 (edited September 19, 2001).]
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
tyeo098
Nov 30, 2015 06:27 PM
1Aauto
Sponsored Vendors
Sep 22, 2015 03:39 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
