custom TQ ARM mount for my ford 8.8 swap
Old Jun 6, 2009 | 03:19 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
ok guys, heres the finished product. steel is 3/16" mild steel, partially tig welded and the rest is mig welded. the tubing is 1/8" thick. the assembly slips over the snout of the pumpkin(center section) and then has 2 brackets that slip over the pumpkins supports which will be drilled (see holes) and bolted to the pumpkin with grade 8, 1.5"x 3/8" bolts. its pretty close to the stock setup as far as the tq arm mount on the stock 9bolt. My TQ arm is an aftermarket Jegster shorty tunnel mount tq arm.
im pretty happy with the way it turned out... its a really tight fit (bang on with a mallet) even with the bolts not put in i cant pull it off or twist it at all. i wanted it to be removable which is why its not welded but there are a bunch of points at which i can if i ever decided to down the road.
now all thats left is to dissassemble the rear(axles,posi, etc) transfer my brackets over from my 9bolt and then put it all back.
let me know wat you guys think. i took a couple of ideas from some members,BMR, grannys etc. and im super jealous of anyone with a plasma cutter since cutting 3/16" steel with a sawzaw and a jig saw is NOT FUN OR FAST! took me 3 days, last day for painting etc. i think its plenty strong but im interested to see what you guys have to say
https://www.thirdgen.org/forums/atta...506altered.jpg
https://www.thirdgen.org/forums/atta...511altered.jpg
https://www.thirdgen.org/forums/atta...524altered.jpg
Old Jun 6, 2009 | 07:48 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: custom TQ ARM mount for my ford 8.8 swap
looks interesting. Im liking it. I assume you have checked out BIGMODS torque arm mount? he has through bolts going through the case itself with nuts inside the diff. They would add some more strength if you are questioning strength.
It seems that all the force would be transferred to the front of the pumpkin, so unless that broke off, all should be fine.
Old Jun 8, 2009 | 09:39 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
You sure thats only 3/16"?? Looks more like 1/4".
Either way...doesnt look bad. Im anxious to see it fully attached and set up with a torque arm. I have a bunch of 8.8s since I collect them apparently haha. I gave thought to using one in an f-body build but I never get past thinking about the torque arm mount. I usually assume that Ide just run a ladder bar type setup.
Nice work...keep us updated with it!
J.
Old Jun 8, 2009 | 10:46 AM
Shagwell's Avatar
Car: projects.......
Looks pretty good, although I might go with 86TA's thoughts on running up the top of the case and through bolting for more leverage.
Heres some pics of one I did. I posted some of these in your original thread when you were debatig about using an 8.8.
Old Jun 8, 2009 | 09:42 PM
Car: 87 TA clone
ghettocruiser... lol yea im pretty sure its 3/16" but if it was 1/4" i wouldnt be surprised! it was insane to cut with a jigsaw and sawzaw. yea im tryin to get it in so i can post pics i just swapped both spring perches/panhard bar bracket to the ford 8.8 from the 9bolt.
shagwell... i wanted to do something like yours but once u welded it to the tubes it was no longer removable. in case i trash the rear i wanted it removable, like the idea of bolt on LCARBS... they work fine bolted in but if i ever wanted to have them welded in i could. also one u welded to the axle tubes u changed the tq arm mount. basically when load is on the tq arm its energy is no longer only forced onto the pumpkin/center section but its transfered to the axle tubes. which would require fully welding the axle tubes. granny in my original thread explained it in more detail. i wanted it to only bolt onto the pumpkin so 95% of the load is transfered to the pumpkin and the axle tubes dont need anymore reinforcement. (this is why granny never welds the tubes to the housing on his rears that he builds) bc its not needed with a stock type setup TQ Arm. still yours turned out nice, but u also made your own tq arm, i will be using the tubular shorty jegster one.... which is designed to fit into a stock type setup at the pumpkin.
pic
https://www.thirdgen.org/forums/atta...531altered.jpg
Old Jun 9, 2009 | 09:17 AM
Shagwell's Avatar
I realize that you were going for a bolt-on type tq arm mount, just saying I would probably run a brace up the top of the pumpkin and through bolt as 86TA noted. You are placing a lot of stress on the one housing brace. - Basically, the pumpkin is going to try to bend the plates/break the one cast section and twist/slide upwards to pivot out of the collar. A section of 1" angle run up the top and through bolted would add a lot of strength to the mount.
Not trying to bash your design, just a little "constructive criticism"; all-in-all you're doing a great job. It is probably fine as is for mild power, but I'm an over-kill person. I'd rather build it to handle 1000hp and have it never put through over 500 than build it for 500 and have some put it through 700.
I did distribute some of the load to the axle tubes, but the down-leg braces that tie to the factory pinion dampner holes also distribute much of that load to the pumpkin. What you can't really see in those pics is that the pipes that run from tube to tube are also welded to the pumpkin for almost 6", on each side of the pipe. Not really worrried about hurting the housing, as it will be assembled with the proper parts from the git-go. Welding the axles tubes is considerably easy when compared to the fab work you're doing.
Old Jun 9, 2009 | 01:04 PM
Car: 87 TA clone
i appreciate ur constructive criticism... not really following you with the 1" angle. if you could draw something out like on a napkin id appreciate it lol. i was thinkin maybe a peice of the 3/16" steel curved to fit the pumpkin set at 90degrees (like the bolted areas) but have it twist and reach around to the back support girdle bolts. wont be able to do this until i get the support girdle which is on the way
Old Jun 10, 2009 | 12:08 PM
Shagwell's Avatar
Welded to the top of your mount and running directly up the top of the housing, then through bolted just before the cover flange. You would have to drill a hole or two through to the inside of the housing. The top would be the most important, and would be less likely to cause you any leaks.
Old Jun 11, 2009 | 02:15 PM
Car: 87 TA clone
is there enough clearance in the inside of the housing to run a bolt? im most worried about the bolt failing and falling into the gears/fluid, or there just not being enough room for the head of the bolt with all the moving parts.
thats kinda what i was thinking... didnt really wanna do the bottom of the housing but the top would be alil easier
Old Jun 19, 2009 | 10:05 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
Nice designs. I wish you guys were round when I did mine a couple of years ago. Either of yours look stronger that the sandwitch design I used. I might have to revise it now that I have a plasma cutter.
Nice job.
kory
Old Jun 22, 2009 | 03:41 PM
Shagwell's Avatar
Just make sure you position it so it's not directly over the ring gear and you'll be fine. A good qualit grade 8 bolt and lock nut would not give you any trouble(use good loc-tite and the primer). - You could drill and tap the housing, so as to have nothing to be able to come loose inside; I'm not sure it would be thick enough to hold well on it's own, but if you tightened a bolt down from the outside a nut on the inside could then be like a jamb nut, thus being very secure.
Old Jul 23, 2009 | 02:00 AM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
what the fu(k is a sawzaw?
Old Jul 23, 2009 | 02:48 PM
iroc a 86 berli's Avatar
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
its that big thing that goes back and forth while vibrating the **** out of u when cutting metal.
Old Jul 23, 2009 | 03:49 PM
Car: 87 TA clone
lol basically this is if u use correct form!
this is a sawzaw
http://www.kwtool.com/catalog/images/newrecip.jpg
Old Jul 23, 2009 | 04:29 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
you must live in a cave, its the greatest invention since duct tape
http://www.amazon.com/Milwaukee-6509.../dp/B0000789HE
Old Jul 23, 2009 | 08:29 PM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
you guys both need to seek some further education.
its a SAWZALL!
Old Jul 24, 2009 | 09:11 AM
Shagwell's Avatar
its a SAWZALL!
that's actually just a trademark name, same as jigsaw; thus like saying every drill is a Dewalt.
Old Jul 24, 2009 | 09:35 AM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
google is your friend, check it out and get proved wrong.
Old Jul 24, 2009 | 01:16 PM
Car: 87 TA clone
its a SAWZALL!
tomato TO MATO... same $HIT! everyone has a diff way of calling/describing something, u must not be a real mechanic... never heard anyone call it a SAWZALL, most abbreviate it to sawzaw.
by the way i googled sawzaw and thats the pic i posted.
Old Jul 24, 2009 | 02:46 PM
take it down a notch
Old Apr 24, 2016 | 04:10 PM
Allen Eger's Avatar
custom, how much you charge to make one and send it my way? im on my 3rd rear end with my ls3 swapped 01 ta and it always breaks when i dont have money to buy a better rear and I need the car right now... so if i could do this and not have to be so worried about it untill I up the power more so
Old Apr 24, 2016 | 10:37 PM
Car: 87 TA clone
Well my ford 8.8 survived behind my 521 BBF, has been as quick at 12s in the 1/4 (traction and valve float issues) and is now behind my 5.3 LS supercharged. This is with the stock 28 spline axles.
I've never contemplated making another one for anyone so I have no idea. I'm not sure if the front nose of the ford 8.8 pumpkin changed at any time either. Is it possible... sure but I don't have a spare rear to build one on.
Old Apr 25, 2016 | 05:06 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
Just asking. Why the ford 8.8 and not the 9 inch?
Old Apr 25, 2016 | 05:46 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
Did you check this. http://www.maximummotorsports.com/MM-Torque-arm-1979-04-Mustang-88-axle-Heavy-Duty-P222.aspx
Check the page for install pdf in faqs. Has installed pics.
Old Apr 25, 2016 | 05:58 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Less weight an less power to turn the 8.8 and they are just as strong. I have built several that have run 7s in the 1/4 in heavy cars.
Old Apr 25, 2016 | 08:56 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
Iron center section prob. comparable weight.
Old Apr 25, 2016 | 12:52 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
That tq arm and its mount points look identical to the midwest fab 9 for thirdgens. Is that their tq arm?
Off their site:
http://www.midwestchassis.com/installed-9-pictures.html#PhotoSwipe1461606697850
Old Apr 25, 2016 | 02:54 PM
Car: 87 TA clone
Bingo! 9" consume the most power of all the rear ends. I would love to get a S60 built for my car in which case I would just sell the ford 8.8.
Ford 8.8s are cheap anywhere from $150-300 for a complete rear.
Most come with trac lock posi... even if they don't they are cheap to get. Posi can be rebuilt or beefed up with cheap friction plates. Pinions and rings are just as strong as the 12bolt. Your only limited by axle size. Most car (non mustang) run 28 spline axles but mustangs and explorers run 31 spline stock.
I have a total of like $600 in my rear including the price of the rear itself, 3.55 gear swap and new seals/bearings, solid pinon spacer, Moser support girdle/cover, ARP Cap studs and a carbon fiber clutch upgrade.
Old Apr 25, 2016 | 04:07 PM
big gear head's Avatar
The FOX and SN95 Mustangs have 28 spline axles in the 8.8. The S197 Mustang was the first to get 31 spline axles.
Old Apr 25, 2016 | 05:01 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
The claims of the 9 inch eating power is way overblown. One magazine did an article and did a back to back on three rearends, just one article, that seems everyone bases their decision off.12 bolt is comparable to a 8.8. It was a miniscule number the difference. Besides that Ive read people who say they have gone faster(before 9inch swap) and some they have run the same numbers( after the swap) Its a wash really and not worth mentioning. The power loss quoted from running a 9 inch youd think your dropping 50rwhp. Put a spool in a fab 9 rear with aluminum case and see where you are weight wise. I muscled my 9 bolt out and put the fab 9 in and the weight was dam close. So is that a midwest tq arm?
Old Apr 25, 2016 | 06:53 PM
Granny's Avatar
2.375" of hypoid offset in the 9" gearset makes them more like a worm gear and less like a bevel gear. Lots of rubbing transferring power thru a worm gear, not much with a bevel gear. More rubbing action between teeth = more heat generated under load = less efficiency.
8.5 10 bolt, 12 bolt, and Ford 8.8 all have 1.5" of hypoid offset.
Old Apr 25, 2016 | 06:58 PM
TTOP350's Avatar
If you can gain a few HP here and there plus drop some weight, esp in a race car, why not?
Old Apr 25, 2016 | 09:40 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
Yes your right. The gain is only a few hp. The hp loss is overstated and overblown. Every internet discussion on this topic quotes that magazine article on rear ends. The hp loss was miniscule to the 12bolt. On a 600hp car you would never know the difference. I like piece of mind though. I never weighed mine but it was the same or less than my 9 bolt, and that is a tooth pick axel compared to the 9 inch. 9 inch is a tried and true vetted axel. What it loses in terms of hp and weight ( and that is using the nodular iron center) makes up for itself in durability and parts availability. Youd think by now most of the bigger manufactures would make an 8.8 bolt in rear for more than just a fox, but they dont. Any reason why? Still wondering on the source of the tq arm and mounting points. Looks exactly like the mwc stuff.
Old Apr 25, 2016 | 11:21 PM
Car: 87 TA clone
Using less hp isn't the only reason, sure it's good to know ur saving a few but does it matter no! The whole point is dollar per hp it's able to handle. Stock 8.8 are stronger than 9 bolts and 10bolts and are the same price if not cheaper most of the time and not to mention the cost of replacing parts are cheap compared to the 9 bolt. Even then the cost is comparable to a 10bolt but the parts are stronger.
If your going to spend the money on a 9" u might as well just go strange 60. Stronger than the 9" and cost about the same.
Also 8.8s are found just about everywhere, mustangs, crown Vic, Mercury marquis, F150s yadda yadda. They are fords go to rear.
Speaking of the 9" strength first time I was at the strip guy was loading his car at the line and BAM car lurched forward and out came the 9" in peices. Even then I know their strong but I just not a fan of the design and the offset pinon. There are better designs out their. Hell even my RAM has the Dana 60 in it.
Old Apr 26, 2016 | 04:35 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
Shagwell,s your tq arm on one you made a mwc piece? Same mounts and arm as mine.
Your setup looks simaler to this in this thread:
http://www.yellowbullet.com/forum/showthread.php?t=515423#/enter
Actually looks like the Hawks one too:
http://www.hawksmotorsports.com/hawks-custom-82-2002-camaro-firebird-8-8-rear-end-assembly/
Click the pics.
Old May 8, 2016 | 05:43 PM
bigfish1047's Avatar
Car: 1984 Berlinetta
Engine: 355
Transmission: 350
Axle/Gears: 4.30:1
I started mine about 8 years ago, drove it, then removed to have it narrowed. I got it narrowed, Eaton posi, 4:30 gears and lost interest for awhile. I'm getting back to it. I have 235 miles on the engine. I think it was an 84 crown vic, needed spring perches and torque arm mount. Now it needs axles and brakes. I'll play with the 7.5 4:10 posi for awhile.
Old Mar 3, 2019 | 07:00 PM
riosj2's Avatar
need this part do you sell them?
Old Mar 3, 2019 | 07:03 PM
riosj2's Avatar
whats the price thanks
Old Mar 3, 2019 | 07:30 PM
Car: 87 TA clone
nope, it’s a one off. Good news is the rear is still in service and has survived no issues. It’s now holding up to 3 years of boosted 5.3 LS or about 650 crank hp. I’ve also drilled the axles out for GM bolt pattern with a hand drill and run MT street Drag radials and all is ok.
Old Mar 3, 2019 | 07:45 PM
riosj2's Avatar
were did you buy it?
Old Mar 3, 2019 | 07:48 PM
Car: 87 TA clone
i made all of it.
Old Mar 5, 2019 | 06:29 AM
  #42
kenbob's Avatar
Car: 86 trans-am 1LE G92 WS.6
Engine: 305 LB9
Axle/Gears: 2.77 soon to have 3.45
Here is something that you might want
Old Mar 5, 2019 | 08:15 AM
  #43
Car: 87 TA clone
Yes Ive seen those and Ive also heard of them failing at the welds... since that style needs welding to the cast iron case. Its a very difficult thing to weld cast for the average person. I can weld pretty well on most metals but I'm not comfortable on welding cast iron given its such a stressed/important key suspension piece.
Old Mar 5, 2019 | 10:03 AM
  #44
kenbob's Avatar
Engine: 305 LB9
If you have a machine shop perform the service it will be fine, or use a high nickel rod most welds break because these people used the wrong welder or didn't get proper penetration. I suggest a machine shop because who else has more experience welding cast iron and they usually guarantee their work. Yes on some of these welds break but it's usually because of installation experience and a lack there of
Old Mar 5, 2019 | 10:19 AM
  #45
Car: 87 TA clone
Sure but then you have added cost of transport, paying for the service, plus once its welded your $hit outa luck if you screw up that rear. That actually happened to me... I totaled my first rear (slid into a curb) and bend the axle tube and snapped the axel while destroying the rim. I just slid the bolt on tq arm mount and slid it over the replacement rear. Had it been welded it would have been wasted. Also. its not usually just the rod thats the issue, with cast iron you have to/should preheat the area for welding and then have a slow cool down. Just saying that cast iron is a finicky little biotch and I prefer not to have the strength of the part be depended on a cast iron weld.
If you can weld or know someone who can lay a good cast iron weld the bracket kit you posted would be of great value as long as you don't destroy the rear. Overall costs I have less in my material than purchasing that kit and its reusable.
Old Mar 17, 2019 | 01:48 AM
  #46
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
Transmission: 5 speed
i
Frozer!!!
Jan 19, 2024 04:55 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Dialed_In
Aug 20, 2015 01:45 PM
