Can you hear your rear end whinning when you drive?
Old Sep 19, 2001 | 06:40 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
well mine does
its not like loud where people can hear it outside of the car.....but if i roll up the windows and turn off the radio i can hear it
also i was wondering if i were to rebuild my rear end....would it b able to hold 400torque?
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
new best E.T. (dont laugh) 15.986 @84.93mph
old best E.T 15.997@86.04
http://www.geocities.com/K_towngangsta
Mods-
K&N Air filter
Old Sep 19, 2001 | 07:38 PM
ede's Avatar
ede
richmonds are cut differant and make more noise than gm or other gear sets. as a rule i'd say no usually you don't hear it. is the oil level correct?
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Sep 19, 2001 | 09:07 PM
bad@ss89camaro's Avatar
Car: 91 Z/28 convertible
last time my rearend was whining i checked the rear fluid and it was bone dry i filled it back up but it was to late it forever whines now
92 25th annv. camaro
midnight black
stock 305 tbi
t-tops
89 camaro
carburated 305
bored .030 over
flat top pistons
bigger valves
heads and block shaved
spoiler
tinted windowshuge white chevy symbol on back
92 stock rims
92 ground effects
www.geocities.com/thirdgenerationcamaro
Old Sep 21, 2001 | 11:32 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
yah i checked the other day and it is still full
and i drained some of it and put as much as i could fit in there
Mods-
K&N Air filter
Old Sep 22, 2001 | 05:03 PM
OLDYELLR's Avatar
Car: '85 IROC
From the way you describe it, it's not loud. My '83 whined a little and I drove it like that for 15 years with no change or problems. After I blew the posi and spider gears on my '85, it whined a bit when coasting at low speed after I put the Torsen in. However, I believe that was because some of the pinion teeth were scored. It seemed to get louder as time passed and whined all the time after I got back from Memphis, so I had the gears replaced. The new gears were Richmond and whined just a tiny little bit, but I'm used to it now and don't even notice. I'd say if it isn't getting any louder, don't worry about it.
1985 Yellow IROC-Z 5.0 HO, T-5 3.73 Torsen, 4 wheel disks
PFCM pads, GTA wheels, Koni yellows, B&M Ripper, Dynomax
Old Sep 22, 2001 | 10:48 PM
Jay 727's Avatar
Some early f body rears ('82 and up) had a problem with the torque arm mounts distorting the rear end housing. I think they fixed it by mid '83. Probably not the problem but worth looking at.
Old Sep 23, 2001 | 12:23 AM
EvilCartman's Avatar
Car: '82 Z28
Mine whines only when coasting I had a look at the gears and the spider gears were chunky looking (replaced them) but the ring and pinion looked fine.
'82 Z28
LG4 305 .030 over, performer intake, holley street avenger 670, xe 256 cam, tes headers, 3 inch single exhaust, spintech muffler, 14 x 3 inch drop base k&n.
Old Sep 23, 2001 | 02:14 AM
89Irocz23's Avatar
make sure its not the fuel pump you here...lol..jk
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
