creeps forward
Old Jun 10, 2009 | 09:57 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
creeps forward
I have a '90 RS 305 TBI T5.
The synchros are worn on many of the gears. But another problem is with the clutch I believe.
When it's cold the clutch operates perfectly, however when it heats up to operating temperature the clutch starts slipping I think.
I'll be at a stop and #1 it will be hard to put it into gear and #2 it will start to creep forward slightly. This only happens when it heats up. What could it be? Clutch cylinder fluid?
Thanks to anyone that can help.
Old Jun 10, 2009 | 10:15 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
Re: creeps forward
Sounds like the pilot bushing is starting to drag on the input shaft after it heats up. That would be a cause for those symptoms that you have.
dmccain
South East Region
Sep 30, 2016 06:23 AM
tommy z-28
Oct 6, 2015 10:58 PM
shanelique22
Sep 24, 2015 06:30 PM
RedLeader289
Sep 23, 2015 06:50 AM
camaronils
Sep 20, 2015 02:57 PM
