9 bolt carrier question
Old Sep 22, 2001 | 01:47 AM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
hey i have a borg warner 9 bolt with the 3.08 ratio, i called randy's ring and pinion and he told me 3.73's would run me bout 325 but i dont know which carrier its for the series 2 or the series 3, if its for the 3, is there a spacer made do adapt the series 3 gears to my series 2?
Old Sep 22, 2001 | 12:22 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
if you have a 9-bolt you don't have 3.08's. 3.08's are for a 10 bolt. You have either 2.77's 3.27's or 3.45's(only found in the 5 speed cars)
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM ClarkeMustGoNow***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Old Sep 22, 2001 | 12:55 PM
86IROCTHD's Avatar
Car: 88 Trans Am
on the back of the diff cover it had a tag on it that said 3.08 ratio. unless it was put on there by accident then i dont know. but i pulled it off an 86 trans am but dont know what tranny it had, how can i check the rear and see what they are?
Old Sep 22, 2001 | 08:42 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Apparently there ARE 3.08 9-bolts out there, but they are very rare. If you have one, its a 2-series, and you'll need a new posi unit to go with the 3.73 gears. Make sure those 3.73's are for 7.75" 9-bolts. Most 9-bolts use 3.70, but 3.73 is available too.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Sep 23, 2001 | 12:23 AM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Randy's (as well as all the others) only have the weaker 10 tooth 3.70 ratio (even though they advertise it as a 3.73). I have up to 4.10 ratios (including an 11 tooth pinion 3.73) and series 3 posi carriers available.
With the 3.08 ratio, you will need a series 3 carrier to install a ratio numerically higher than 3.08.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
Currently installing 3.73's into my 9 bolt (YES, it is a 9 bolt & YES they are 3.73's, not 3.70. I currently have 4.10 gear sets and new series 3 carriers in stock for 9 bolts )
www.koolmeister.com
Old Sep 23, 2001 | 12:34 AM
u r sofa king we tah did's Avatar
is there anyone that sells gears for the 2 series carrier?
Old Sep 23, 2001 | 11:18 PM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
What ratio do you want? Anything numerically higher than a 3.08 will require either a series 3 carrier or a space (which is not recommended).
Miles
88 427 Camaro
www.koolmeister.com
Old Sep 24, 2001 | 02:13 AM
taliesian's Avatar
hey 88 427,
how much are your series 3 carrier's?
Old Sep 24, 2001 | 10:24 AM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Check you mail.
Miles
88 427 Camaro
www.koolmeister.com
Old Sep 25, 2001 | 09:24 AM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
Miles, or anybody who knows.
Can you rundown a list of which stock gears fit on which series of carriers. Aftermarket ones would be fine too. I'm just wondering what I need to look out for
are the 3.27 and 3.45s for 3 series and the 2.77s for 2 series? I would imagine this is the case, but I just don't know
thanks
Clem
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission (hopefully not for long)
Old Sep 25, 2001 | 02:48 PM
Momar's Avatar
I have an 85 T/A. It had a non limited-slip 9 bolt with 3.08s in it. I now have a limited slip 9 bolt with 2.77s. The housings have the same numbers on them. I was wondering if it would be possible for me to have the 3.08 gears put in the limited slip rear end or possibly combine the gears to make a numberically higher ratio and keep the limited slip functionality. Thanks for your help.
Old Sep 25, 2001 | 07:54 PM
Kevin91Z's Avatar
Its my understanding all 9-bolts in f-bodies are posi and disc brakes. For you to have an open 9-bolt is strange. Are you sure its an open, or maybe its just a dead posi?
3.08 and numerically lower is a 2-series. 3.23 and numerically higher is a 3-series. All 2-series gears are interchangeable, and all 3-series gears are interchangeable, but you cant switch between 2 and 3 series.
Old Sep 25, 2001 | 11:31 PM
Momar's Avatar
Nope, it is drum brakes and open carier. I have had the cover off. I looked the number up in the hanes manual and it lists it as a borg warner open carier unit. I would like to at least get my gear ratio back up to my 3.08s. Does anyone know how much it would cost for a series 3 carrier. Can I use my gears out of my other rear end. If so does anyone know what ratios they would yeild. Just to refresh you they are 2.77 and 3.08 with the series 2 carrier.
Benjamin A. Brohez
Old Sep 27, 2001 | 10:36 AM
TexasLT1's Avatar
Car: '92 RS
a while back someone said that they had made a 1/4" spacer so that you could use 3 series gears on a 2 series carrier. Id look for that post and talk to him. sorry I can't offer any more information
-'92 RS with self-installed '95 LT1
-Heddman Headers
-TPIS throttle body airfoil
-MSD 6-AL Ignition
Kills
-'97 Mustang Cobra
-'98 V6 Camaro
-'89 5.0 ****stang
-'97 Sebring
-'96 ****stang Cobra
Losses
-'99 Mustang GT
-'96 Mustang Cobra
-'95 Z28 (good race)
-'96(?) Turbo Eclipse (d*mn good race, heavily modified)
hectre13
Dec 11, 2023 08:14 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
hectre13
Aug 26, 2015 08:17 AM
redmaroz
Aug 16, 2015 11:40 PM
knight72
Aug 10, 2015 09:32 PM
