Tranny question...
Old Jun 14, 2009 | 06:44 PM
Camaroguy6984's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI L03
Transmission: TH700R4 Corvette servo
Axle/Gears: 10Bolt 2.73
Tranny question...
I know of a v6 5 speed for sale local for cheap, my question is, will i be able to swap that trans into my auto car, and im not asking "can a 5 speed b put into a auto car" i know u can do that, i need to know that if i buy this car i can make my car into a 5 speed, so v6 man to v8 auto, will it fit and work, simple swap of bell houseing? dont wanna buy a parts car for parts that wont work, plus go though all the work only to start cursing WAY more than doing a swap i know can be done.
Old Jun 14, 2009 | 06:49 PM
redfox's Avatar
Car: 91 rs, 97 firebird
Engine: 3.1, 5.7
Transmission: both 700r
Re: Tranny question...
the v8 transmission are bigger, and more bolts on the housing, than the v6 even if there both 700r, as far as the 5 speed to an auto. I have no idea
Old Jun 14, 2009 | 06:53 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
You would need to buy a V8 F-body bell housing and a special clutch set-up with a 10.4in disk with a 10 spline shaft. I don't know if the V6 clutch hydraulics will work on a V8 though.
Old Jun 14, 2009 | 11:25 PM
Car: 1989 Camaro RS
Engine: 305 TBI L03
just so there is no confusion on the question, i have a v8 auto, and found a possible doner car that is a v6 5 speed, and put that 5 speed into my auto
Old Jun 14, 2009 | 11:38 PM
redfox's Avatar
Engine: 3.1, 5.7
ok, the v8 tranny is bigger than a v6( built wise) you probily could swap them but doubt it will hold up to all the power the v8 has
Old Jun 14, 2009 | 11:55 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
I understood that, if you read my first post it has listed the other things you would need to make a V6 T5 work behind your V8.
Also depending on the year of your car and the donor car something may have to be done with the speedometer.
Old Jun 15, 2009 | 09:21 PM
Car: 1989 Camaro RS
Engine: 305 TBI L03
sorry, wasnt tryin to sound like a ****, so yes it could work, but would prob kill the tranny, so dont do it, got it =)
Old Jun 15, 2009 | 11:34 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
It's all good,
I don't know about the strength difference between a V6 and V8 tranny. I would assume a WC is a WC and an NWC is an NWC, when I did my swap I had a few guys try to sell me V6 transes with all the parts to put them behind a V8. My friend is into Fox Body Mustangs and he actually looked for the 4cyl trans for his cars because he figured they weren't beat on as much.
You would still probably be better off just buying a V8 trans swap set up, so you don't have to find a bell housing or a special clutch. I posted up in the WTB section and got about 10 offers in 3 days before I picked up a complete WC setup for 500.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
