Difference on TCC lock-up system?
Old Jun 16, 2009 | 01:48 PM
camaro87-alex's Avatar
Car: 1987 Chevrolet Camaro SC
Just curious...
Is there any difference on the TCC lokcup system on 87 models?
I have a 87 Camaro was stock 305 computer controlled carb engine.
I have finished my TPI swap on the engine and have some prolems with the lock-up. The TCC connector and the cable colors are the same on both TPI and carb wiring harness...
I am just curious if this could have something to do with my lock-up problems...
Old Jun 16, 2009 | 05:20 PM
transtalker's Avatar
Car: 95 Suburban K1500
Engine: 355 TBI,heads,cam,flowmaster exhaus
Transmission: 4L60E custom rebuild, mod shift kit
Axle/Gears: 3.08 front and rear
Re: Difference on TCC lock-up system?
what kind of problem are you having with lockup? but the answer to your question is no there is no difference between the lockup plug they are all a 4 wire system
Old Jun 16, 2009 | 10:31 PM
I am having a big problem at low RPM's in drive and over drive.
When RPM on the car reaches about 1000RPM and the car is about to shift from 4th to 3rd the car is almost jumping from 750RPM to 1200RPM..
The car continue this shaking until i hit the brake pedal or give a little throttle.
Could this be something with the solenoid that is not working?..Or mayby the ECM?...
I tried to test my TCC connector today and when ignition key turned to ON, I got 12V on all three wires. The wires are one purple, one blue and one tan/blk.
When I ground ALDL connector terminal A and F I got 12volts on 2 of the wires except the tan/blk wire wich is grounded. Got zero volts on that one.
9192camaro
16
Feb 3, 2019 12:21 AM
jklein337
Sep 19, 2018 06:23 PM
backtothe80s
Sep 5, 2015 12:39 AM
TheExaminer
Aug 26, 2015 04:59 PM
Stauf
Aug 24, 2015 08:31 PM
