The quest fot a 3.42 posi drum rear...
Old Sep 20, 2001 | 02:21 PM
BahamutRS's Avatar
I need one.
Badly.
I can't find one anywhere; I'm not spending cash on a ring and pinion set, posi differential, etc. NO.
I can't get a disc rear, because that swap is like impossible times ten thousand in my 92 RS.
Where can I rip off a 3.42 posi drum? What cars did they come stock in, or didn't they?
I can scounge the junkyards for modded cars, I guess, but I figured I'd ask first.
I need this. Thanks
1992 Camaro RS (Auto) 5.0L TBI
Performance mods
NOS (125 HP shot)
Dynomax cat-back exhaust
Hedman headers
K & N open element/ X-Stream lid
MSD 6A ignition
MSD 8.5mm plug wires
LT1 camshaft
Soon to be installed:
Edelbrock intake manifold
B & M 2400 RPM stall torque converter
B & M shift kit
World Products Torquer heads
Audio
Sony Xplod CDX-M610 head unit
Pioneer 2-way 4x6 front speakers
Pioneer 3-way 6x9 rear speakers
12 inch Pioneer VCCS PRO subwoofer
QLogic sealed box
Kicker ZR360 amplifier
Lightning Audio 1 farad capacitor
Other
Macewen White Faced Gauges/Shift overlay
A-pillar gauges (Phantom oil pressure, Air/Fuel)
180* thermostat
Window Tint
Old Sep 20, 2001 | 02:22 PM
BahamutRS's Avatar
Ok, quest FOR. NOT FOT. :P
Old Sep 21, 2001 | 09:59 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
My 12/85 "86" Z28 came with posi 3:42's on drum. As far as I know it is the original rear end, so you might shoot for 85/86.
SSC
85 Camaro, 355/400 "drag car" in moth ***** 13.1@ 101mph on its last season run.
Plans: Possibly add N20 for next season.
82 Firebird, 305/350 currently being moth balled.
Current plans: Rebuild 305 with flat tops instead of the dished "cups" for pistons or slightly built 327 with the 58cc heads from the LG4, Upgrade the 2:73 to 3:73 or 3:42 and replace the turbo 350 with 700r4.
"web site under contruction"
Old Sep 21, 2001 | 11:41 PM
matty350TPI's Avatar
I have a ten bolt with 3.08's a posi, and drums. And have 3.42's in a box ready to go. But the problem is a I am in Toronto Canada. Anyways let me know.
Old Sep 22, 2001 | 12:28 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I think you can find 3.42 drums in V6 cars, the T5's.
My dad put an 89 9-bolt disc brake rear end in his 92 RS without any trouble. Whats the trouble with yours?
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Sep 23, 2001 | 02:40 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Go to the junkyard and grab a rear out of a 91-92 or so 3rd gen with a v6 and an auto. I never saw one that wasn't a 3.42, but check to be sure and check the axle splines to make sure it's a 28 spliner. Then get the SLP takeoff torsen posi and all you need is carrier bearing shims and marking compound and to check the backlash. If you can't score shims from the auto store I guess you could get the half install kit from jegs or summit.... I had some shims laying around. I noticed the stock shims arn't going to line up with the torsen, I guess it's production variation or something....
Total cost involved: $25 for the complete rear from a pull-it-yourself, $79 for the SLP takeoff (They were on sale, but I never saw them priced over $99)
It's a simple operation since you don't need to take out the pinion, I was done in less than and hour.
Old Sep 24, 2001 | 09:37 AM
Boham92RS's Avatar
I got my 3.42 posi drum rear off of a 91 Z28 w/ T5.
Old Sep 28, 2001 | 05:25 PM
Trevor K's Avatar
Check the tech data part of the site. It lists all the gearing for 3rd gen cars broken down by year (Even by stick vs auto). This would make it easy to find the desired gear ratio, and increase your chances of finding a rear without having to count the teeth...
Of course, you'll have NO idea whether the gears would have been changed or not so I guess you'll be counting the teeth anyways...
Trevor
87 Z28 - LG4 - 305
Hedman Headers, Y-Pipe, Dynomax Exhaust, K&N Open Air Filter
http://immortaltk.tripod.com/z.html
Old Sep 30, 2001 | 09:02 AM
merf23's Avatar
I have an original 3.73 rear from an 84 L69 car. Its has aluminum drums, no posi with about 58000 original miles. It needs a brake job, but is otherwise OK. $150 if your interested.I live in connecticut.
email me at merf23@yahoo.com
1984 Z28 (L69) monochrome tangerine orange with IROC decals and hood
1987 IROC wheels with Goodyear GSC's
305 from 87 IROC with 1994 LT1 cam (203/208 .450/.460")
performer intake
Qjet from 73 Olds
dynomax cat-back, gutted cat
no emissions controls --> passed emissions testing
non WC T-5 with 0.73 5th
3.27 nine-bolt
Old Oct 1, 2001 | 04:35 PM
TMoNeE's Avatar
Car: 87 Z28
<font face="Verdana, Arial" size="2">Originally posted by Kevin91Z:
</font>
yea i put a 9 bolt disc rear on mine too.. easy swap.
KO1
16
Oct 15, 2015 05:00 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
