time for a new trannie, need help
Ok my 700-r4 is on its way out and I am looking for a new trannie. My problem is that I can't afford to rebuild it so I am looking in the want ads for other options.
option 1) get complete donor 5 speed car and switch to that
option 2) find another 700-r4, do transgo shift kit, and tc lockup kit (I don't have a computer)
option 3) get th350 and suffer on the highway
My question is, what would be my best bet here? I know the T5s aren't the strongest but my 350 isn't a beast either and I would like a 5 speed (but not if I'll kill it easily)
If I go with the th350 do I need a long or short tailshaft? are the bolt patterns for chevy's and pontiacs the same? (I am assuming they are but correct me if I am wrong)
I have the stock rear end w/ singletrack 308 gears and do a good amount of highway driving on the weekends. the th350s are a lot more abundant in the want ads than 700-r4s which is the main reason I am considering it.
Sorry one last question, will I have any problems with a rebuilt 700-r4 from a mid 80s vette?
thanks in advance
Jay
Jay's Website
No car with 4 doors is a sports car! this goes back to my friend comparing his Maxima to a Camaro
thanks in advance
Jay
Jay's Website
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
The TH350 will fit, but you'll need an adapter to bolt up the torque arm.I know one guy that used the tailshaft housing off a TH2004R, instead, but he builds trannies all the time,so I don't know if there were other mods required as well.Most are unhappy with the TH350 in this application, because of the lack of OD.Switching to a T5 will require a lot of parts from the donor car,pedal setup,hydraulics,bellhousing,flywheel,clutch,t.o. bearing,pilot bearing,shifter,console insert,etc.Best T5's are the latest (90-92)
but still are rated at less than 300 Ft/lbs and your 350 probably puts out more.If you don't hammer it or bang gears it'll be ok, but what fun is a stick without doing that?
Also, I think the tailshaft housing on the corvette trans uses a totally different mounting setup, so you'd have to at least change that to use that trans. I'd bite the bullet and rebuild your existing trans or buy a rebuilt outright, if it needs to be back on the road quickly.
-Rich-
1992 RS,5 Speed,T-Tops,Eibach Springs(cut), KYB's, Lakewood Trailing Arms and Adjustable Panhard Bar,Posi Disc Rear,3.73 Gears,Summit Rearend Support Cover,
Del-A-Lum Bushings,300 HP Crate Motor,Crane Comp-U-Cam,Edelbrock TBI Intake, Turbo City Ported Throttle Body and Adjustable Fuel Pressure Regulator,Open Element
Air Cleaner, Ground Control Strut Tower Brace and Caster/Camber Adjusters,SLP 1-5/8" Headers,Flowmaster 3" American Thunder Exhaust,3" Cat,Centerforce Dual
Friction Clutch,Hayes Billet Flywheel,B&M Power Steering Cooler,Big Thumpin' Stereo.
-Rich-
thanks guys,
yes if and when I change the trannie it will have to be a weekend project as this is my only car. Thats kind of why I was leaning towards buying another trannie so that I could do it in one day.
the T5 switch probably won't happen b/c if I have a standard I will want to be able to mess around with it and not worry about breaking it.
Thornburg
Aug 25, 2015 01:46 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
