700r4 questions
Old Oct 3, 2001 | 09:06 AM
unknown_host's Avatar
Car: 1989 Iroc Z L98
700r4 questions
Right now I have a 200c. I know the th350 is a direct replacement for the 200c, but i would really like a 700r4. So these are my questions, hopefully you guys can answer:
What do i need to do to the tranny to make it non computerized. I will have a carbed 350 in it, and will no longer have any of my computer crap.
What will i need to do/get to install the 700r4 where the 200c was?
What is a good price for a 700r4 core?
Thanks,
Seth
Old Oct 3, 2001 | 11:44 AM
92 RSS's Avatar
Car: 1992 Camaro RS
Engine: 5.7
I seen www.tacreationsusa.com has cores for 50 bucks.
What is a core, just the housing or the complete tranny but need rebuilt?????
My Website
92 RS, 350, Street & Performance MPFI, TFS heads, Stock crank and rods, Fordged flat tops,
Crane Rollers,
MSD Digital 6 Plus, 22lb injectors,
ZZ3 cam, Edelbrock Headers 1 5/8, 3" Exhaust,
Hi Flow 3" Cat, stock T-5,
stock rear 3.08, koni yellow adjustable front, twin turbo glass hood, T-tops, Auto Meter Ultra Lite Series 2 5/8 gauges, Teal Green
Est. 365Hp 420+Lbs.
[This message has been edited by 92 RSS (edited October 03, 2001).]
Old Oct 3, 2001 | 01:30 PM
82camaro's Avatar
Car: 82 camaro SC
I've done this swap.
Custom crossmember or drill the subframe(I modified my crossmember)The mounting point is a few inches back on the 700r4.
Cut a couple of inches off the torque arm(couple minutes with a hacksaw)
Shorter driveshaft(30 bucks from junkyard)
The tranny isn't computerized, the computer just locks and unlocks the torque converter(TCI non computer lock-up kit from summit will take car of that)
A 700r4 TV cable and possibly a bracket for your carb(mine worked just fine)
I'm sure I forgot something. Do some searches, this has been posted before.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
camaro11j
Sep 19, 2018 08:49 AM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 11, 2015 10:22 AM
Leggman1
Aug 6, 2015 04:15 AM
