which has less rotating weight, rear rotors or aluminum drums?
Old Oct 2, 2001 | 11:31 AM
92 RSS's Avatar
Car: 1992 Camaro RS
Engine: 5.7
Old Oct 2, 2001 | 02:20 PM
Drakar's Avatar
I would guess at rotors as there is less weight ???? same meterial (alum???) I don't know, Im just guessing.
Old Oct 2, 2001 | 04:06 PM
92 RSS's Avatar
Car: 1992 Camaro RS
Engine: 5.7
I thought the rotors were like cast or steel?
Old Oct 2, 2001 | 04:29 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Rotors are cast iron and some of them have a steel middle component (where it meets the axle or hub flange) and an iron outer disc. Those are called composite rotors and are the lightest style of rotor out there. I would guess that a drum system is going to be heavier no matter what since the brake drum has to have a cast iron friction surface even if it has an aluminum housing and that is going to be pretty heavy. I'm not really sure though........ they (al drum vs. iron disc) would be pretty close on rotating mass I bet. The other thing to consider is that the drum's mass is farther away from the center axis of the axle or hub compared to a disc, which is undesirable......
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Oct 3, 2001 | 02:13 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
But, drums fully release from the contact surface, where-as there is some amount of drag between a rotor and pad setup, which is undesirable and a reasom many drag racers use drum brakes.
Old Oct 3, 2001 | 10:27 AM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
In the case of disc vs. drum, both being iron, the disc setup will always be heavier than the drum setup. Remember you have the disc itself (which has more mass than a drum), the caliper, brackets, etc ... While the drum has only the drum (less mass), and some srpings with the support being the axle plate. I have two 10-bolt rear ends (one disc and one drum) and the disc are very noticably heavier than the drum rear end. Now if you are comparing the aluminum drum to disc, it's a no brainer ... Al drums are lighter. This setup is ideal for drag racing (in a limited budget class), but disc are better for road racing.
George P. Lara
1984 Z28
2001 SS #0391
SCCA, SCFB, SC3GFB, SSOA #M01-0391
Old Oct 3, 2001 | 10:47 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
FYI, the '89-'92 rear disc brake setup is MUCH MUCH lighter than the earlier setup. I weighed them and seem to remember roughly about 9-10 lbs per side less. The calipers are aluminum vs. iron, and the rotors, while larger in diameter, are much lighter (I assume because they are thinner).
That setup seems to weigh less than cast iron drums and all the associated drum hardware.
Old Oct 3, 2001 | 11:54 AM
92 RSS's Avatar
Car: 1992 Camaro RS
Engine: 5.7
I guess i'll stick with the aluminum drums. Anyone know the P/N for these????????
My Website
92 RS, 350, Street & Performance MPFI, TFS heads, Stock crank and rods, Fordged flat tops,
Crane Rollers,
MSD Digital 6 Plus, 22lb injectors,
ZZ3 cam, Edelbrock Headers 1 5/8, 3" Exhaust,
Hi Flow 3" Cat, stock T-5,
stock rear 3.08, koni yellow adjustable front, twin turbo glass hood, T-tops, Auto Meter Ultra Lite Series 2 5/8 gauges, Teal Green
Est. 365Hp 420+Lbs.
Old Oct 3, 2001 | 06:22 PM
WECoyote's Avatar
92 RSS,
Aluminum Drums: 1255496
Cast Iron Drums: 1249146
Those are GM part numbers and they should be valid.
FYI.......I tried to get the aluminum drums thru AutoZone. They don't carry them.....have to go to GM for those I believe. Cast iron......many places sell aftermarket ones. Hope this helps.
Mike
Old Oct 4, 2001 | 12:11 AM
JoelOl75's Avatar
Advance auto has the aluminum drums. I think they were around $45 a piece.
Old Oct 4, 2001 | 07:15 AM
JoelOl75's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 99Hawk120:
</font>
I re-read your post and I really ain't buying... Maybe aftermarket disc setups. I agree 100%, but the factory rear disc setup really sucks. BTW, the calipers are cast iron. I know, I have two cars with them. One is supposed to have them, the other I converted to discs. After converting I noticed NO IMPROVEMENT in stopping. none. zero. ditto. The back brakes are not stressed very much so therefore fade isn't a huge issue with them.
Also, neither car has an e-brake that works proper. I hooked the cables up, got new ones, got new calipers, and the best the lever does is a very light lock, not even enough to stop the car on a very steep hill. With the drums, 'dem babies were locked!
Another point: The drum brakes are cheaper to service, and ALOT easier to change. For those who do the brakejobs and would think the discs would be easier, remember, they are NOT anything like the fronts. The piston has to be pressed and turned at the same time and you must align a notch in the piston with the nub on the pad. A PIA to say the least.
THE ONLY THING FACTORY REAR DISC BRAKES HAVE ARE GOOD LOOKS THROUGH 'WIDE OPEN' MAGS
Old Oct 4, 2001 | 09:37 AM
99Hawk120's Avatar
<font face="Verdana, Arial" size="2">Originally posted by JoelOl75:
I re-read your post and I really ain't buying... Maybe aftermarket disc setups. I agree 100%, but the factory rear disc setup really sucks. BTW, the calipers are cast iron. <snip>
</font>
Look, you obviously have the older style ('82-'88) rear discs. Yes, they suck. Yes, they are cast iron. They also have nothing in common with the '89-'92 brakes which are the same as the brakes on the the LT1 4thgens. Those brakes work pretty damn well, and the calipers ARE aluminum.
If you don't believe me, ask some other people on here.
Old Oct 4, 2001 | 12:46 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
yeah but with disc breaks the ONLY rotating mass is the disc, not the caliper and pads, etc.
-Brian
Old Oct 4, 2001 | 04:41 PM
92 RSS's Avatar
Car: 1992 Camaro RS
Engine: 5.7
I did call my local dealer about the aluminum drums and the were like $160 each!!
Advanced auto $45?? I'll have to check that out.
Thanks for the replys,
I believe the aluminum drums will be lighter than the rotors.
Old Oct 5, 2001 | 11:46 AM
nblanchard's Avatar
Well.... being in my 4th year of Mechanical Engineering, basics show you that drums would have more rotating weight. True that they may weigh less on the scale... but you get them rotating at 1000RPM... the drums weight a lot more rotating weight. All the material on a drum is 4-6" from the center, thus creating a force greater than that of a rotor that the material is almost uniform from center to edge. Plus... you can get some drilled and slotted rotors that will bring weight down even more. I would stick with the disc breaks, expecially if you are driving this on the road as well.
1988 Pontiac Trans Am GTA L98 5.7L, Black on Black with 114,000kms.
Custom 3" Stainless Exhaust Y-Pipe back (High flow Cat and Flowmaster Mufler)
Old Oct 5, 2001 | 12:53 PM
99Hawk120's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Z28 Boy:
yeah but with disc breaks the ONLY rotating mass is the disc, not the caliper and pads, etc.</font>
I'll be damned. Somehow I missed the whole "rotating" part of the original question! Absolutely the 89-92 rear rotors are much lighter than iron drums. I would think the '82-'88 rotors are close.
I've never weighed or even picked up aluminum drums so I have no idea how much they weigh...
But this also begs the question, why is the original person worried about rotating weight? I assume there is a reason behind asking the question.
Old Oct 5, 2001 | 01:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The same reason you put on an aluminum driveshaft and rails run tiny, skinny tires on the front: It takes power to get them moving.
Also, they act like a flywheel when braking.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Oct 5, 2001 | 05:19 PM
99Hawk120's Avatar
Yes, but that doesn't take into account the drag from disc brakes.
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
