Ok...hooking up a TC lockup switch today...i have a question!!
Old Oct 1, 2001 | 11:35 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
can i just leave the TC switch ON(meaning locked up all the time)
Here is my situation...i'm having a problem with hitting closed loop...i think my O2 sensor is shot or i need a heated one(i have headers). Since i'm not hitting closed loop my TC isn't locking up(from what i understand it won't lockup in open loop). So with that said i'm slowly cooking my tranny to death. This switch is temporary until i can figure out the open loop/closed loop problem. Can i just leave the switch in the lockup position all the time? This will keep the TC locked in gears 2/3/OD right? I read Ed's write up on this...should i use a 2 or 3 prong switch? Thanks guys!!!!!!
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM ClarkeMustGoNow***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Old Oct 1, 2001 | 03:42 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You can, but you probably won't like driving it.
Old Oct 1, 2001 | 05:19 PM
fly89gta's Avatar
Car: 2018 Camaro SS
i'll probably just leave it locked up in OD or when i'm going over 35 MPH
Old Oct 1, 2001 | 06:44 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you want a nicer way of doing it, the 4th gear switch grounds the B pin on the TCC connector to tell the ECM when the transmission is in O/D, and the ECM locks the TCC by grounding the D pin. Just put a wire between the 2 pins and you'll have automatic lockup in 4th.
Old Oct 6, 2001 | 09:15 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Actually fly, i had to use my switch driving up tp penn state one time, my CTS went out so the TCC wasn't locked. No good w/ a heavy load on a long mountain highway drive, so i just locked it up while i was at speed.
Much more convenient than using the 4th gear circuit, that can be a pita cuz then it is always locked in OD
Ed Maher - Moderator @ The TPI & Carb Boards
92 Z28 Convertible - Quasar blue / Tan top
305 TPI A4 2.73 - 14.8 @ 93.1
Stock except ported plenum and dual cats
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 2, 2015 10:29 AM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
