th700 to t-5 ??'s
Old Oct 2, 2001 | 12:10 AM
Purple Monkey's Avatar
Car: 1990 Eagle Talon TSi AWD
Engine: 4G63T
Transmission: 5 speed
th700 to t-5 ??'s
How much torque can you shove through a 91 t5 out of a camaro with a 305 tbi? I have a somewhat mild carbed 350...
Old Oct 2, 2001 | 09:26 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
91-92 T-5's are among the best of that trans available,but it's still very weak.I think they're only rated at about 285 Ft/lb,while the earlier ones are only 250-265.I used to beat mine pretty good with a stock 305 TBI motor (second gear rubber daily), but at about 80K I had it rebuilt,as it no longer stayed in second gear.The rebuild kit for these trannies are expensive, and although a friend of mine (who works at a manual trans/rearend shop) rebuilt it for me,I think I'd have been better off buying a Tremec,Richmond or T56.Mine required 2 gears, a shift fork and an input shaft bearing retainer (actually, the third)and for about $500 more I could have had a better trans,although it would require other changes.I recently put a 300HP 350 and a posi,3.73,disc rear in mine, and am hoping the trans lasts through the winter,but I know that I'll have to replace it by spring.If you don't drive your car hard (banging gears and dumping the clutch) it will work, but keep in mind that even a stock 170HP 305 is capable of breaking it.
-Rich-
1992 RS,5 Speed,T-Tops,Eibach Springs(cut), KYB's, Lakewood Trailing Arms and Adjustable Panhard Bar,Posi Disc Rear,3.73 Gears,Summit Rearend Support Cover,
Del-A-Lum Bushings,300 HP Crate Motor,Crane Comp-U-Cam,Edelbrock TBI Intake, Turbo City Ported Throttle Body and Adjustable Fuel Pressure Regulator,Open Element
Air Cleaner, Ground Control Strut Tower Brace and Caster/Camber Adjusters,SLP 1-5/8" Headers,Flowmaster 3" American Thunder Exhaust,3" Cat,Centerforce Dual
Friction Clutch,Hayes Billet Flywheel,B&M Power Steering Cooler,Big Thumpin' Stereo.
Old Oct 2, 2001 | 09:29 AM
Car: 92 Camaro RS
Oh, by the way,if you are going to use a T5, be sure and run synthetic fluid in it.It's worth the little xtra $.
-Rich-
Old Oct 2, 2001 | 02:21 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
DONT BOTHER... putting in a T-5 is just as much work as putting in a T-56 and the price tag is very similar.
The T56 is strong, the T5 isnt.
The T56 has six gears, the T5 has five.
All of these elements add up to say.... forget the T5 and go T56 if a manual swwap is what your looking for.
1989 Chevrolet Camaro IROC-Z
L98 - 350c.i. TPI, rebuilt 700R4 auto w/shift kit, Dual catalyst Monza PaceSetter Cat-Back, SLP 1 5/8 Coated Headers, 3.23 Posi rear, Hypertech chip with 160stat, MSD 6A, Under-Drive pulleys, AFPR, K&N's, !Air Box w/ Ram Air, moddified MAF, !TB Coolant, Spohn Dual Cat SubFrame Connectors, Alarm, Keyless entry, remote starter, 92 Z28 AeroWing, Brand New Paint (6/21/01)
Future: ZZ4 TPI w/EGR, T56, 3.42 or 3.73, Spohn strut tower brace and LCA's, Accell 24# injectors
1989 Chevrolet Celebrity Eurosport <--DEAD AS OF 9/20/01
2.8 MPFI, no mods
225,000 miles and still ticking!
More info and pics on my webpage:http://go.to/iroc-z
AOL IMer: GPA 0point0
Old Oct 2, 2001 | 02:55 PM
jayman350's Avatar
<font face="Verdana, Arial" size="2">Originally posted by L98IROCZ89:
</font>
that is assuming that he is going to buy a brand new one. I am currently considering a swap to t5 but no way am I buying a brand new one. I am looking for an entire donor car to take the stuff out of.
Jay
Jay's Website
No car with 4 doors is a sports car! this goes back to my friend comparing his Maxima to a Camaro
Old Oct 6, 2001 | 05:57 PM
Engine: 4G63T
Ok, so that's a definite no then...
Ok, well i guess i'll just pay the 600 for the t56 instead of 450 for the t5, then i gotta get the x-member though, oh well, it's not going anywhere anyways...
THanks a lot.
PurelyPMD
May 5, 2016 04:57 PM
Zane Story
Oct 8, 2015 12:40 PM
luvofjah
Sep 26, 2015 08:28 PM
DARKmj16
Sep 9, 2015 04:07 PM
Formula_88AE
Sep 3, 2015 01:47 PM
