I am looking at these. Are these the correct size and will they work (As the picture shows the threads a bit short). I'd like to replace my rear end cover with some nice new SS Bolts since I bought a new cover. Thanks
http://www.summitracing.com/parts/ARP-622-1750/
is it a cast aluminum cover or stamped? those bolts are way to long if its stamped, but should be fine with a cast cover
This is my cover, the bolts that came with it, 10 are 5/16-18-1.75", 2 are 5/16"-18-2"
http://www.summitracing.com/parts/MSR-7105/
http://www.summitracing.com/search/?...437-3001&dds=1
You need these. The 2 longer bolts in your cover set are if you have E-Brake cable guides mounted to your diff.
no those are too short, he need the 1.75 onesOriginally Posted by BADMAN
http://www.summitracing.com/search/?...437-3001&dds=1You need these. The 2 longer bolts in your cover set are if you have E-Brake cable guides mounted to your diff.
My bad,but that is what my ARP catalog calls for,must be stock style cover application. He got it right the first time,will need (2) packages of the 622-1750.
Thanks guys. Appreciate it.
I just checked out this website and they are saying the bolts are a different size?
Who is right?
http://www.accuautoparts.com/axledes...leid=G75REAR26
Who is right?
