Just bought a 82 Z and what the F***
Transmission: 4L80E/4L80E
Turbo Hydramatic 200 with lock-up torque converter. 3-speed, no overdrive.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Car: 1989 C4
Axle/Gears: 307
<font face="Verdana, Arial" size="2">Originally posted by Torqomeo:
crappy 3spds. How hard is it to get a 4l60 in there?? Does anyone know what i would have to modify?</font>
A turbo 350 would pop right in there!
SSC
I looking for more driveabilty then anything else. Thats why i like the 700r4. Can i get one outa any truck/Van or does it have to be another v8 f-body? Also would i have to change my driveshaft?
Car: 91 Red Sled
I'm not really sure about the driveshaft but you shouldn't have too get a new one. If you do, just go to a junk yard and pickup a $30 f-body driveshaft (pretty sure you won't have too). The TH700r4 should go right in but I'd like to know how you plan on shifting it. Good luck
, Jon (350 TBI!)
91 Red My website
, Jon (350 TBI!)
91 Red My website
Car: 1989 C4
Axle/Gears: 307
Yep you need a drive shaft and a shifter.
Any "besides 2.8 or 4x4" 700r4's will work.
The shifter and the drive shaft will run you a good $80-100 and if you want a fairly easy swap get the crossmember for a 700r4 $20.
Ive swaped a 350 for my 700r4 the reverse process of what your doing and now am doing the same swap you are in my other fbody so my parts price quotes are fairly accurate and make for an easy swap.
SSC
85 Camaro, 355/400 "drag car" in moth ***** 13.1@ 101mph on its last season run.
Plans: Possibly add N20 for next season.
82 Firebird, 305/350 currently moth balled.
Current plans: Rebuild 305 with flat tops instead of the dished "cups" for pistons or slightly built 327 with the 58cc heads from the LG4, Upgrade the 2:73 to 3:73 or 3:42 and replace the turbo 350 with 700r4.
"Web site under construction"
G0D Bless.
SSC
G0D Bless.
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
