Should I convert from 700r4 to T-5?
Old Jun 23, 2009 | 11:20 AM
frbdgirl92's Avatar
I just bought an '89 Formula 350, and the car is in excellent condition. However, the interior needs to be installed but before we go about putting it in I was thinking of putting a T-5 transmission in the car. The 700r4 that's in it is in great condition but to be hones tI ride a bike and I like having full control. So I was wondering if anyone has any advice, tips, etc? Is there any reason I shouldn't and what do I need to worry about when I do?
Thanks.
Old Jun 23, 2009 | 02:57 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
Re: Should I convert from 700r4 to T-5?
T5's aren't rated for a for a whole lot of torque, but if you don't beat it, you will be fine. Easy swap. If I had to do it again I could probably knock it out in under 3 hours with a competent helper.
Old Jun 23, 2009 | 04:31 PM
frbdgirl92's Avatar
Good to know. I just want a manual transmission but I think I might have too much torque for a T-5. Any other suggestions?
Old Jun 23, 2009 | 04:40 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
t-56 or super t-10
t-56 is a 6 speed
super t-10 is a 4 speed
i'd go with the t-56 if it were me
only drawback is the pricetag
the t-5 WILL last if:
a) you dont have sticky tires
b) you have relatively high rear gears (ie, no 2.73's or anything lower than 3.42 or so)
c) you drive it like you have a bit of common sense.
i dont have one, but many people put t-5's behind a mild or even more than mild 350 and do fine.
just dont take it to the strip and expect it to last more than 2 runs or so.
Old Jun 23, 2009 | 07:13 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Pro Built's modified Trans Go shift kit.....Makes driving the automatic waaaay more fun than when it's stock. I love mine. And the reviews for it on TGO are nothing but good.
Old Jun 23, 2009 | 08:52 PM
frbdgirl92's Avatar
I appreciate the advice but I really just want a manual transmission. I'll probably look into getting the T56. Any suggestions where to start looking?
Thanks again.
Old Jun 23, 2009 | 09:02 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
hawks thirdgen parts will have a complete swap kit IIRC.
after them, people on the board may be selling kits with everything you would need.
if you dont have any luck there, buy a LT1 or LS1 4th gen that was wrecked and take everything out of it that you need. then part it out and get some of your money back... you might even break even if it has desirable interior parts in good shape.
basically just dont go and buy a spanking new one unless you have to.
you will spend way too much money IMO
Old Jun 23, 2009 | 09:26 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
u need a LT1 T56, not an LS1 style one, the LT1 style will be pretty much a direct bolt in..look to spend between 800-1500...
Hotrodboba400
Dec 10, 2019 07:07 PM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
DARKmj16
Sep 9, 2015 04:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
