t5 build-up
Old Jun 25, 2009 | 05:57 PM
kowalzekc's Avatar
t5 build-up
Ok, I looking to build a t5 to handle a decent amount of HP/Torq. I was wondering how hard is it to build a strong t5 and where can I get parts for this or a build kit???
Old Jun 25, 2009 | 06:16 PM
Jekt's Avatar
Car: 1983 camaro
Engine: 350 soon to be 355
Re: t5 build-up
try doing a search youll more then likely find it fast.
Old Jun 26, 2009 | 10:04 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Re: t5 build-up
Hard isn't the word I'd use. It isn't hard; what it is is expensive. Where to get parts is easy; G-Force. Using their gears, mainshaft, and case you can built a T5 that will handle 600HP and 500 lbs/ft.
Old Jun 26, 2009 | 03:22 PM
kowalzekc's Avatar
Re: t5 build-up
So here is my next question. What would be a good alternative to this then? I have heard of people doing a coversion on the t56 that basicly drops two gears and still maintains similar overall gearing of a five speed and can handle a sucker puch of power. Meaning that the four speed conversion gives the t56 some lengthy gears.
Old Jun 26, 2009 | 05:47 PM
Jekt's Avatar
Car: 1983 camaro
Re: t5 build-up
if your building up your engine you will need a better trans. you either have to spend like $2300 on g force or you can get the after market t-56 for about the same. most go and get a LT1 t56 and swap that in. i would say its still about $2000 for everything unless you get a really good deal on the trans.
Old Jun 26, 2009 | 06:58 PM
Re: t5 build-up
It all depends on what you are looking for. Manual transmission strength just doesn't come cheap. You can build your T5 with superalloy gears and get it up to 350 lbs/ft., or you can go the G-Force route and you are looking at $1,100-$2,600 depending on what all you replace.
You can swap to a Tremec for around $2,500.
You can swap in a T56 for somehwere between $2,500 and $5,000 depending on exactly which parts you use/reuse. The LT1 T56 is a much better choice than the aftermarket one IMO. The only way I'd use the aftermarket T56 is is I already had a bunch of money tied up in a scattershield, flywheel, and clutch. Otherwise the hassel doesn't justify it.
WhiteLightnin83
Jul 12, 2006 02:20 PM
Maverick_IX
Feb 15, 2006 06:06 PM
TA4me
Jul 5, 2005 02:55 PM
raefon
Dec 31, 2003 12:01 PM
Mrfixit
Jul 18, 2001 12:35 PM
