6 Speed Trannys??
Old Oct 5, 2001 | 01:55 PM
Warrior's Avatar
Car: 98 Camaro/85 Camaro
Engine: 3.8L/ 355 CI
Transmission: Auto/ TH350
Axle/Gears: 3.23 Posi
6 Speed Trannys??
Hey i have a 5 speed in the my current Third Gen i was wonderin how much it would cost for me to go and get a 6 speed that would be compatable with it... I need some more gear to kick some Ponys!!!
Old Oct 6, 2001 | 08:44 AM
ede's Avatar
ede
a tremac will set you back several thousand
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Oct 6, 2001 | 09:16 AM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
You have a few options:
Richmond R.O.D Six Speed: About $3000 and can handle up to 450 ft.-lbs.
3.27 2.13 1.57 1.23 1.00 .76 is the cheapest option
BW T-56 From a 4th Gen Z-28 or Firebird Formula/Trans-am: Fairly strong but people have been having clutch problems with this
BW T-56 from a viper: Very strong, hard to find
All of them require some trickery to install i.e. Special Bellhousing, Moving the shifter back/forward
-Don't buy any wooden nickels
Old Oct 8, 2001 | 04:53 AM
jimbuck's Avatar
I just did the swap to a T56. It was not too bad at all, and boy what a difference it makes. It sure is a lot of fun too. Just find the T56, and get the complete thing from the donor car, trans, clutch, all sensor plugs. You will also need a crossmember. And get a new master cylinder from Dal. that is about it.
Jim Buckingham
91Z, 350 TPI T56
Old Oct 13, 2001 | 06:49 PM
Mark W. Winning's Avatar
The stock t-56 swap is almost brainless. If you get the transmission with the slave cylinder and shift and you buy an aftermarket crossmember, its an afternoon job. I love mine. I run about 300-325 Hp and it feels great. I installed 3.73's also, but wish I had used 4.10's.
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Old Oct 14, 2001 | 01:03 AM
Warrior's Avatar
Ok but what all came with the T-56?? besides buyin one brand new... what used/parted out cars should i be lookin for to get one from? the only one i know of besides the Viper which would be very hard to find around here is the newer SS right?
Old Oct 14, 2001 | 06:37 AM
jimbuck's Avatar
Get any 93-97 T56, can't use the one from an LS1. Get the tranny, clutch, shifter, lower boot and the bolts. Look the clutch over good and re use it if it is ok. You will need a console cover (bought mine used for 30 bucks), and a cross member. I would recommend getting a new master/slave cylinder. Cost $84 from Dal.
Old Oct 14, 2001 | 06:09 PM
89 4Mula 350 Tbi's Avatar
jimbuck what do you mean about the console cover?
Old Oct 14, 2001 | 08:24 PM
toosloz's Avatar
spohn seels a nice cross member with a torque arm set up made for a 6spd install in which i will be buying soon
84z28HO
355
open element/k&n
m5/hurst billet plus shifter
83 z28 fiberglass hood
9bolt w/3.27 posi
performer intake
performer 600cfm carb
accel 8mm wires
adjustable thermostat switch
160 stat
gta rims
gts blackouts
s.s rear control arms
s.s panhard rod
s.s subframe connectors
98 camaro rear springs,shocks
98 z28 leather seats
95 camaro rear view mirror
"wonderbar"
http://www.geocities.com/toosloz/84camaroz28.html
Old Oct 15, 2001 | 11:55 AM
jimbuck's Avatar
Woops, sorry, did not see that you had a 5 speed. I needed a manual cover going from an automatic.
Old Oct 15, 2001 | 04:47 PM
If you have a one piece rear main motor, get everything from the flywheel back, including the front drive shaft yoke. The T-5 front yoke will fit, but the T-56 yoke is longer and prefered. Also, get the slave cylinder and line from the donor car. The T-5 and the T-56 slave cylinders are different, but bolt up the same. I used the stock T-56 shifter and its clears the T-5 console in every gear. Looks like it belongs there. Look for 94-97 T-56's. The 93 had a different first gear, slightly deeper, but had a lower torque rating.
adelane
Sep 9, 2015 08:51 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
