Trans Stop Leak: Should and can I use it????
Old Oct 10, 2001 | 09:36 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
I want to sell this car. The leak isn't that much, but its leaking from the rear of the transmission and the front seal. Like I said though, very little. It seems to do it more when the car is on ramps. I do not have the money to fix it and I want to sell it and let some1 with money fix these things. Its not big so maybe it won't start going crazy right away for the next owner, I suppose u guys know how I feel. Thanks!!
89 RS
STILL Looking For:
An 87 IROC-Z28 350 TPI
[This message has been edited by IROCZTWENTYGR8 (edited October 10, 2001).]
Old Oct 10, 2001 | 01:28 PM
Administrator
BTTT. Guys I need a quick answer to this, some1 must know!! Should I use that stuff or shouldn't I?? Thanks!!
Old Oct 10, 2001 | 03:02 PM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
Just give it a try!
It will cure the leak(s) for some time!
Old Oct 10, 2001 | 05:47 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
If you do, get the stuff made by Lucas. It's supposed to be pretty good.
91 Z28
Come see The Vicious...
Old Oct 10, 2001 | 06:01 PM
Pro Built Automatics's Avatar
The front seal is a silicon type trans leak does nothing for this. New seals & possible bushings are the only way. Do not put in any type of trans stop leak it will destoy the inner seals of the transmission. This stuff acts like carberator cleaner, if you put something that is made of rubber in it, it just keeps growing. Finally in about 2-3 weeks the transmission quits altogether. It can help in special cases with different type of transmissions but I would not try it here, it will come back to haunt you.
Old Oct 10, 2001 | 06:27 PM
Administrator
I already did, the 1 by Gunk. Is it OK, what should I do??
Old Oct 10, 2001 | 11:01 PM
Administrator
Old Oct 10, 2001 | 11:39 PM
Nordbert's Avatar
I would drive it for a few days and then change the fluid and filter. I have seen seals that had some kind of stop-leak used on them and they were swollen and rubbery.
Not sharp on the edge of the lip like they
should have been. I don't have a clue what brand of sealer was used, however.
Old Oct 11, 2001 | 01:54 AM
Administrator
Why couldn't some1 tell me this before!! I've always been against this type of stuff, but I want to sell it and if it would stop the leak from the rear of the trans, it would help. The front seal leak is slow but the rear is faster.
Old Oct 11, 2001 | 12:37 PM
Administrator
PBAutomatics, what should I do??
Old Oct 11, 2001 | 03:54 PM
Ptu in a new seal & bushing in both the front & back if you want to do this right. The stop leak is not going to work it will most likely destroy the transmission. If there was something that worked, I think I would have seen it by now. But it still is possible that there might be something out there that will work.
Old Oct 11, 2001 | 07:26 PM
Administrator
I can't pay for it right now, and I've never messed around with a trans before besides adjusting the TV Cable!! It actually made it feel better.
Old Oct 12, 2001 | 10:32 AM
Administrator
Should I change the fluid or leave it in there??
Old Oct 13, 2001 | 10:54 PM
Administrator
It did stop the leak though.
Old Oct 15, 2001 | 01:30 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Well, if you're selling it, why bother? Replacing the rear seal isn't rocket science; but to do the front seal, you'd need to drop the trans down and out.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Oct 15, 2001 | 04:22 PM
Administrator
Lets see, why bother?? To Get More $$!! Do u have to take out the trans to replace the rear seal?? Its leaking again. If some1 could explain it good enough I'd probably be able to do it.
[This message has been edited by IROCZTWENTYGR8 (edited October 15, 2001).]
Old Oct 16, 2001 | 12:13 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
You shouldn't decieve someone when selling anything...
That kinda patch and hide stuff gets me miffed if I buy something. I'd rather have the person tell me what's wrong with the car, than to try to hide the problems and they crop back up 1 week later.
Old Oct 16, 2001 | 12:25 AM
The transmission does not have to come out to replace the rear seal & bushing. The Drive shaft, torque arm, and tail housing are all that need to removed.
Old Oct 16, 2001 | 03:05 PM
Administrator
I'd rather not sell it like that also, but I need the $$. If some1 could give detailed precise instructions I will do it myself and won't have to keep it from the buyer. The front seal is barely leaking, maybe a drop every few days, maybe even better than that, but this rear seal is going crazy. Its getting to the point to where I'm going to have to change it, but if some1 experienced could explain I would really appreciate it. I haven't messed with transmissions yet besides adjusting TV Cables, but I have the tools to do this stuff and can follow good instructions.
Should I change the fluid and filter too, its still got that stop leak in there?? I've had enough of this.
[This message has been edited by IROCZTWENTYGR8 (edited October 16, 2001).]
Old Oct 17, 2001 | 02:24 PM
Administrator
Any1 experienced that wants to take a go at explaining this go right ahead.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
hokis
Aug 9, 2015 03:57 PM
