4th gen rear installed
Old Oct 17, 2001 | 10:53 PM
88transam5.0's Avatar
Hi, I just installed my "99" 4th gen rear and its a 3.23 disc. Rear works great and my braking is alot better than before,I hope! I used to have the 2.73 drum brakes and I'm still using the same proportion valve for drums and seems to be working fine, does anybody think I'll have problems being the valve is for drum brakes. And my second question is I feel my speedometer is off, can anyone tell me what speedo gear I would need for this swap. I looked at the tech article for gears but its way above my head. and also, my tranny feels different shifting (Auto 88 5.0 TPI) since I installed the rear. Almost feelings like its shifting too soon and a little harsh and the O.D. doesn't seem to kick in sometimes. I didn't have these problems before. I sure would appreciate the input. Thanks.
Old Oct 18, 2001 | 08:15 AM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
Probably cuz your transmission thinks it's going at a speed that it's not and it's shifting accordingly, but that's my guess. You defintely have to recalibrate your speedo and maybe it'll get back to normal.
92' Camaro RS 305 TBI
Best 1/4 mile - 14.6 @ 96 mph w/NO NOS
Best 60' - 1.9 secs
Check it out
https://www.thirdgen.org/rides/index.tgo?action=view&rideid=4860
Old Oct 18, 2001 | 01:46 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Go over to www.sethirdgen.org There is an awsome rear end swap article that i used when i did mine. It gives you some great instructions on how to remove the speedo gears. I HIGHLY recommend you get the 32mm wrench, i didn't and ended up breaking the drive gear putting it back on.
*edit* put the wrong website in!!... twice!
  • 89 Formula 305 WS6
    SFC's, LCA's, Air Foil
    Spohn Panhard Bar
    Flowmaster Cat Back, Tranny Cooler
    A/F Ratio Meter (not a mod but it sure spurs interest)
    Trans Temp Gauge
    Most "Free" Mods
    3:73, Zexel Torsion Posi
    Catco cat
    CAI W/ K&N
    15.559 @ 88 MPH
    (Not good enough)
[This message has been edited by Omega (edited October 18, 2001).]
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
AkDrifted
Aug 17, 2015 07:45 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
