95 4l60e problem
Old Jul 4, 2009 | 07:56 PM
zbo2's Avatar
95 4l60e problem
have a 95 4l60e that the parking paw won't disengage. it will go into forward and reverse but won't move with the paw staying engaged. i pulled the pan down and thought it would be something that i would see right away, but no dice. there were no parts or pieces in the pan. i've never had one of these apart before so i'm not sure if i have to drop the valvebody or look somewhere else.
thanks
Old Jul 6, 2009 | 02:02 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 95 4l60e problem
do not drop the valve body, there is no need. Is the car parked on a steep hill? If so, that's where to start, if not, next is following the linkage back, and seeing if you broke the release spring.
Old Jul 6, 2009 | 10:39 PM
zbo2's Avatar
actually, after getting a light and looking at it closely. for lack of a better term, the bullet at the end of the actuating rod somehow went through the metal bracket that is supposed to keep that from happening. it went to the back of the case. now i just have to see what i have to do to get it back where it belongs. there doesn't seem to be enough room to shove it back through the bracket without dropping the bracket down a little. to do that it looks like i might have to drop the valve body. any suggestions?
pjsparts
Oct 29, 2025 06:39 PM
383cam
Sep 9, 2015 06:01 AM
IROCZ1989
Sep 4, 2015 11:54 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
