79' 5.7 - 85' T5 tranny issues
Old Oct 20, 2001 | 09:55 PM
frankie's85Z28's Avatar
I've just finished putting a 79' 350 engine into a 85 Z28 with a 5 speed(T5).The swap was going well until i started to bolt on the starter from my 305.The bolt pattern on the starter was not matching up with the 350 diagonal bolt pattern.I then tried a number of diffrent types of starters, but no matches. Please help if you have a solution to this. Thank you in advance
Old Oct 21, 2001 | 08:27 AM
ede's Avatar
ede
as far as i know gm only had 2 starter bolt patterns, straight and diaganol.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Oct 21, 2001 | 05:28 PM
87RS402's Avatar
Incase you didn't find the link in the other thread where you asked about this I'll post it again.
https://www.thirdgen.org/messgboard/...ML/002835.html
As you can see, we tried every concievable way around it. Although I am suprised that your 79 block doesn't have the extra hole, my 76 block does.
Old Oct 21, 2001 | 09:33 PM
bhaas's Avatar
My 1977 block has both bolt patterns. Maybe it's just truck blocks that have both patterns. Who knows. Your gonna have to drill that extra hole. Drill it with a 5/16 and tap it with a 3/8.
Brad...
1986 SC Camaro
Mods: Threw 2.8 in garbage, put in rebuilt
350 .060 over, XE268H Comp cam, Edlebrock
Performer Intake and Edlebrock 600 CFM Carb,
Pete Jackson noisy GearDrive (which sounded
cool for about 5 minutes, now I'm sick of it)
Rebuilt TH350, 3.42 Rear Gears. LCA RLB's.
B&M Mega Shifter.
Now has T5 in it. YES!!!
CenterForce Dual Friction Clutch.
Cornholio7979
Sep 20, 2018 02:31 AM
blackz281le
Jan 11, 2016 07:51 AM
777Shock777
Oct 29, 2015 04:30 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
