DRIVE PINION QUESTION
Old Oct 24, 2001 | 06:40 PM
Calderone's Avatar
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
A drive pinion from a 9 bolt 2.73 Rear is the same used in a 10 Bolt 3.08 ?
Please help im new in Rearends
Old Oct 24, 2001 | 07:55 PM
Jay 727's Avatar
It won't work. Ring and pinion gears are made in sets, even two sets of 3.08's should not have the gears switched from set to set.
Old Oct 25, 2001 | 12:32 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
The 9 bolt is a 2.77, not a 2.73 ratio and no, they are not interchangable. Ring and pinions are lapped into match sets and should only be used as a matched set.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
Currently installing 3.73's into my 9 bolt (YES, it is a 9 bolt & YES they are 3.73's, not 3.70. I currently have 4.10 gear sets and new series 3 carriers in stock for 9 bolts )
www.koolmeister.com
Vintageracer
Jan 10, 2020 05:33 PM
ezobens
Aug 19, 2015 10:29 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
