T56 clutch not disengaging, pulled apart and found this...
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Apparently the clutch has never even PARTIALLY disengaged... look how perfect that pattern from the friction material is on the pressure plate. There's an identical pattern on the flywheel that matches the OTHER side of the clutch disc. The stupid thing might as well have been welded together.
I've SEEN the clutch fork pulling on the throwout bearing with my own eyes, so i have NO idea what is wrong. Anyone have any ideas?
"Beware he who would deny you access to information, for in his heart, he dreams himself your master"
'84 Black Camaro Sport Coupe ZZ4 350 M6 -- '84 Olds Cutlass Supreme 231 A3
'91 Medium Blue Metallic Z28 400 A4 -- '99 Navy Blue Metallic Firehawk #120 346 M6
Car: '89 Formula
Engine: 355 TPI
Axle/Gears: 3.70 9 bolt.
The latest and greatest I read recently was that STAR clutches really worked great for LT-1 T-56 stuff. http://www.specpwr.com/
It was in a 'camaro performers' magazine or sumthing like that... maybe a super chevy or chevy HP... can't remmeber... I'm old.
The other crap I read was that for the LS-1 T-56's, that there is a restrictor in the hose to the slave cylinder that needs to be enlarged. I need to drink more coffee to remember where I found that.
I dunno, I'm still using the stock LT-1 clutch that was in great shape that I got with the T-56... figured I'd get the bugs out and burn that up first.
Clutches I don't like: clutchnet.com fiber/kevlar/carbon. - too harsh - likes to break T-5's.
Clutches I like so far: Centerforce 2 - like 5 years in my Shelby Z and still works great.
'89 Formula - Thunderchicken - 355 Vette L98/T-56/3.70 9-bolt/black/t-tops - the fun car!
'90 GTA - The GTA - 5.0 LB9/TH700/3.27 9-bolt/black/t-tops/tan leather - the cruiser.
<font face="Verdana, Arial" size="2">Originally posted by ScreaminDeamin85Z:
is that the Mcloed clutch with a lt1/lt4 pp?</font>
And no, the disc wasn't in backwards. The other side of the disc is clearly labeled "flywheel side".
I'm trying to get ahold of a "used", known good T56 STOCK clutch and see if that works. If it does, I'll compare it to the one of I got.
rsrmoore
Aug 7, 2015 08:44 PM
