700r4 swap to t5
Car: proud owner of a 1987 trans am
Engine: turbo 355
Transmission: t5
700r4 swap to t5
got the auto trans out only to figure out my sb chevy flywheel bolt pattern to the crank is larger the t5 came out of a 85 trans am with a carb 305 going into a tpi 305 can anyone help?
Engine: turbo 355
Transmission: t5
Re: 700r4 swap to t5
i have got no reply on this thread but i did some research of my own heres what i have found out the trans am i got the flywheel and tranny from is an 85 the trans am im putting it in is an 87 in 1986 they made a change to the rear main seal it went from a 2 peice to a 1 peice seal therefor making a change to the bolt pattern on the back of the crank the 87 is smaller than the 85 in diameter
Car: 1991 Firebird
Engine: 3.1L V6
what im thinking of doing is swapin out my 700R4 to a t-5.
what kinda work is involved in doing this swap...the t-5 is out of a S-10...would i be able to use pedels and master cylinder from the s-10?
C409
Sep 1, 2015 03:42 PM
Eric-86sc
Aug 24, 2015 09:01 PM
