1-2nd shift is ahrd in 700r4
Old Jul 17, 2009 | 07:16 PM
5.0blackcamaro's Avatar
Car: '88 Camaro SC/Z28
Engine: 305tbi
anyone else got a 700r4 that shifts harder from 1-2nd than any other gear? Is it normal?
Old Jul 17, 2009 | 07:40 PM
mtwlkn122's Avatar
Car: 91 Firebird, 06 Dodge Ram 1500 SLT
Engine: 3.1L, 4.7L
Transmission: 700r4, 45RFE
Axle/Gears: 3.23 open, 3.55?
Re: 1-2nd shift is ahrd in 700r4
Do you have a shift kit?...if you do and you got the full out one instead of the one good for street driving it will shift HARD
Old Jul 17, 2009 | 08:25 PM
y84pauloflondon's Avatar
Car: 87 T-Top GTA
For the 9 years that I've had my 87 GTA 350, YES, AND I LOVE IT....... Remember the GTA's and IROC's got the 700r4 from the corvettes. Its not a "Corvette trany", for lack of better words, its GM's proformence trany that all 3 cars have. It's a 700r4 that been beefed up for our cars...awsome
Old Jul 17, 2009 | 08:54 PM
Engine: 305tbi
no, the car is 100% stock with only 63k original miles.
Old Jul 17, 2009 | 08:55 PM
Engine: 305tbi
no, car is 100% stock with only 63k original miles
Old Jul 17, 2009 | 09:05 PM
Car: 87 T-Top GTA
If you ever has a problem or drop/brake your tranny, sooner or later it will, TRUST ME take it to a GM dealer for oem stock replacment... Or a well know/trusted tranny shop if you go aftermarket rebuild.... Last year the tranny blew and i took it to Mr. Transmission. I Told to just fix what broke, told them about the hard shifting all through out the gears and not to change that... My Car WAS all numbers matching until I found out that these types of shops usaully try to keep replacements in stock to guaranty fix time... Remember that our trans uniqe, the one that they put in was from some like Family car..... and shifted like one aswell. Since june of 08 its been back there 6 time to make it shift right. GM takes yours, fixes it and put YOURS back in using the right parts....(i don't work for Fu**** GM), just info you should know.
Old Jul 17, 2009 | 09:09 PM
Car: 87 T-Top GTA
Do you find that it shifts harder the first drive of the day, when your engine and tranny are cool?
Old Jul 17, 2009 | 09:35 PM
Engine: 305tbi
no, it does it everytime i take off from a red light or stop light with just normal acceleration. It shifts very firmly.
Old Jul 17, 2009 | 10:16 PM
Car: 87 T-Top GTA
I've been fight to get that firmness back.....your luckly....lol
Old Jul 21, 2009 | 03:44 PM
89IROCZDG3's Avatar
Car: 89 Iroc Z
Engine: 5.7 TPI
Axle/Gears: Moser 9 inch , 3.50 gears
My 700r4 has the Transgo shift kit in it and yes it shfts hard from 1st to 2nd. Even under very light acceleration it will chirp the tires. the previous owner put the shift kit in and went a little too far with it.
Old Jul 26, 2009 | 12:44 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Mine shifts very firm into 2nd and 3rd, but 4th is really soft and kinda slow.
Old Feb 17, 2010 | 11:00 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
I miss my car, shifting points were firm throughout...
Old Feb 17, 2010 | 11:10 PM
matts86cam's Avatar
Car: 1986 chevy camaro z28 coupe
Engine: crate 355
Transmission: 700r
i have the 700r4 and even with 170,000 miles on the stock engine, 305, it would spin the tires between 1st and 2nd even when I am not really getting on it.
I had to take special care to not chirp the wheels when I was driving in town. I thought it might have been the tires but after putting 4 new one on, still did it. Being inexperienced, I was kinda worried about it at first but after talking to a few guys in here, I realized that I am one lucky mo fo and thats the way it should be.
Old Feb 20, 2010 | 05:02 PM
Pro Built Automatics's Avatar
Re: 1-2nd shift is hard on the 700r4
There are a few reasons that the 1-2 shift is hard. If the accumulator spring in the 2nd accumulator is broke. If there is a valve body kit, such as B&M which shifts hard all of the time. The TransGo Shift kit installed incorrectly or has the accumulator feed passage blocked or restricted. Second gear feed hole size in the separator plate, way to large. Mismatched accumulator spring and/or accumulator valve that controls the 2nd accumulator feed/bleed. To solve this, you have find out which 2nd apply servo you have, and you have to remove the valve body and separator plate and make the appropriate changes. I suggest the modified TransGo Shift kit, that comes with the Corvette servo, and larger boost valves. This will give you the best of both worlds. Smooth shifts at part throttle, firm shifts at WOT, better downshifts, etc.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
