do i need to cut driveshaft for 12 bolt?
Old Jul 19, 2009 | 01:47 PM
73duster's Avatar
i have a 91 z28 with 10 bolt rear. I just ordered a 12 bolt rear from dts, do i have to shorten my driveshaft?
Old Jul 19, 2009 | 04:02 PM
big gear head's Avatar
Re: do i need to cut driveshaft for 12 bolt?
Did you get a 1350 yoke? If you did then you should get a new drive shaft made to take advantage of the new yoke. If you have enough power to need a 12 bolt then you probably have too much power for a stock drive shaft. The stock drive shaft will probably be about 1 inch too short.
Terrell351
Jun 13, 2021 01:13 PM
Eric-86sc
Apr 3, 2016 03:52 PM
LittleFranks
Aug 20, 2015 03:55 PM
Dialed_In
Aug 20, 2015 01:45 PM
