TKO vs. T-56 dilemna
Old Sep 21, 2001 | 09:42 AM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
I currently have a two piece rear main block, standard bellhousing, 14'' flywheel with a 4 speed transmission. I need overdrive. The t-56 ($2300)is going to require finding a 1982-83 t-5 bellhousing to use my mechanical clutch linkage, plus x-member mods, provisions for a mechanical speedo etc. The TKO ($1958)from forte's is pretty much bolt-in except for driveshaft shortening.T-56 is 6 speeds, TKO is only 5 but is stronger. Would I develop gear envy? Comments, suggestion?
355 c.i.
Dart 180 Heads
Lunati 224/224 cam
Harland Sharp 1.5 rockers
Performer RPM Manifold
Holley 600 cfm double pumper
Hooker Super Competition Headers
Flowmaster Exhaust
Competition Engineering Sub-frame connectors
Super T-10
GM posi 3.42 rear
Hurst Roll Control
13.9@102
Old Sep 21, 2001 | 03:02 PM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
No driveshaft shortening is required on the TKO & it's pretty much the strongest manual trans on the market & it's a pretty straight forward install. I bought mine from Fortes, $2200 shipped to my door including speedo sensor, crossmember adapter, etc. Love it!
'91 Z28 1LE; 355, Sportsman II heads, Edelbrock TPI w/ 58mm TB, Tremec TKO 5-speed, 3.73's & much, much more
Old Sep 21, 2001 | 09:16 PM
Dan87IROC-Z's Avatar
If you can afford it ($3000), you should buy the Richmond 6 speed, its the best manual transmission on the market. If you're like me, and don't have the money, I'd go with the Tremec. I'm just not much of a fan of the T56s.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Accel High Flow TPI Baseplate, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, Jet TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
Old Sep 27, 2001 | 08:06 PM
JoeCool's Avatar
I bought a Tremec 3550 and all the stuff they said i needed. Did not bolt up as easy as you said yours did.mine came from the same place..did you get a shifter lever? i dont know what to do..maybe you can tell me what you got with yours...maybe am missing something
Old Nov 2, 2001 | 10:02 AM
twiztidz28's Avatar
Car: 86 Z28
Engine: 355 carbed
Transmission: t-5
where can i get a tko transmission. are they in catalogs or do they have a web site.
86Z28, 350 gm motor, Borg Warner 5 speed, hurst shifter, 3.73's, Edelbrock heads and carb, Edelbrock headers and cat back 3" all the way, 2 1/2" cowl induction hood, and K&N air filter.
Old Nov 2, 2001 | 10:11 AM
ScreaminDeamin85Z's Avatar
do a search on the net for a place called Fortes parts exchange. the address might be www.fortesparts.com but i am not sute. if the link wont work just do a search on yahoo.com
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons,Hooker Comp headers, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 24lb SVO injectors, crane AFPR, all going through 3 inch mandrel pipe and a flowmaster.
New project-89 IROC-305 5spd...Jamex Springs...and thats just about it!Soon- 6 speed, Pro 5.0 shifter and 4.10's
http://ScreaminDeamin.cz28.com
Old Nov 2, 2001 | 11:51 AM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
I bought the TKO. It should be here in about 4 hours. I'll post pictures if anyone is interested.
Old Nov 2, 2001 | 02:55 PM
Ed1LE's Avatar
Engine: 5.7, 5.0
<font face="Verdana, Arial" size="2">Originally posted by JoeCool:
I bought a Tremec 3550 and all the stuff they said i needed. Did not bolt up as easy as you said yours did.mine came from the same place..did you get a shifter lever? i dont know what to do..maybe you can tell me what you got with yours...maybe am missing something</font>
JoeCool (dig the name!), you posted this a month ago so hopefully you're past this point but if not, here goes. The Tremecs are still basically Mustang tranmissions modified for our F-body's. So the shifter is in the stock mustang location, 2 inches or so to far forward for ours. Mine didn't come w/ the handle but I used my Hurst shifter & modded the handle. We took a 2" piece of steel, welded it to the shifter handle & bolted it to the shifter. It's right where it should be & w/ almost a year & 4K miles of beating on it, no problems! Enjoy!
deracer
Apr 11, 2016 12:04 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
tonys91rs
Oct 10, 2015 03:31 PM
3.8TransAM
Sep 17, 2015 02:16 PM
jharrison5
Aug 19, 2015 05:53 PM
