T-56 pressure plate to flywheel bolt torque
Old Jul 22, 2009 | 07:59 PM
remltr's Avatar
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
I've read the torque to be anywhere from 22-52 ft/lbs? Someone have an answer? When taking apart the old PP/FW it felt more like 22 ft/lbs.
Old Jul 22, 2009 | 10:46 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: T-56 pressure plate to flywheel bolt torque
gm recommends a weird way to torque them not sure the exact torque but after you get the spec u need to turn them a 1/3 more after the torque really weird i think i just torqued them to 40 but DON'T hold me to it
Old Jul 23, 2009 | 04:25 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Tighten to 15 ft.lbs then tighten 30 degrees
Old Jul 26, 2009 | 09:28 PM
89IROKCONVERT's Avatar
this is funny i just went through it myself 2 weeks ago and put my car together today i guessed it out at 35 ft pounds and broke 1 bolt streched 5 it took me two weeks to ge new bolts dont break one there are only 24 left in the country its actually 11 pounds and then 1/3 turn from what i read of course i dont have a torque wrench that goes that low so i just did it by feel and used some blue lock tight jic i feel better seeing this post
Old Jul 27, 2009 | 08:20 PM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
I use in/lbs torque wrench for small reading
Fronzizzle
Mar 18, 2019 08:29 PM
BlackphantomZ28
Apr 24, 2016 08:14 AM
86White_T/A305
Aug 17, 2015 12:16 AM
cRoe4
Aug 7, 2015 08:46 PM
