petal assembly
Old Jul 26, 2009 | 01:56 AM
maddog89cars's Avatar
Car: 1989 formula firebird
Engine: 5.0L 305
petal assembly
is it possible to use a clutch petal assembly that is cable driven in a hydraulic assembly?
Or, does it have to be completely hydraulic?
Old Jul 26, 2009 | 02:11 AM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
Re: petal assembly
I cannot attest to the non-hydraulic thirdgen pedal set ups, although from what i understood there was something called a "zbar" and there was no cable, but hydraulic clutch pedals push a rod, whereas cable pull a cable. Not saying its not possible but you would need to modify it.
What exactly are you trying to achieve?
Old Jul 26, 2009 | 10:49 AM
89IROKCONVERT's Avatar
Re: petal assembly
i dont believe it has the mounting holes for the clutch master cylinder but i just got a whole assembly from a 4th gen camaro and it fit fine
Old Jul 26, 2009 | 03:49 PM
Engine: 5.0L 305
Re: petal assembly
im trying to run a t5 in my firebird and get rid of my 700r4. i found a camaro in my local salvage yard and i thought that maybe i would be able to use the petals from the car at least
Old Jul 26, 2009 | 03:51 PM
Engine: 5.0L 305
Re: petal assembly
i will try to find a 4th gen. to take the parts from.
Old Jul 26, 2009 | 04:08 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Re: petal assembly
What year is your bird, what year is the junked camaro? The majority of thirdgens, i think 84 and up (someone correct me if i am wrong), all used hydraulic clutch release systems and they are all interchangeable.
I am fairly certain you have to use the 4th gen hydraulics if you use the 4th gen pedals.
Old Jul 27, 2009 | 01:31 AM
Engine: 5.0L 305
Re: petal assembly
mine is a 89 formula and i want to take the petals from a 4 cylender camaro. not sure thats year some where between 1982-85.
Old Jul 27, 2009 | 05:28 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Re: petal assembly
You are going to most likely need to get a hydraulic pedal set up if you plan on running hydraulic release on your clutch..
Old Jul 31, 2009 | 01:48 AM
Engine: 5.0L 305
Re: petal assembly
o, ok thank you
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
skinny z
Oct 5, 2015 06:23 PM
gord327
Oct 3, 2015 01:25 PM
Dragonsys
Sep 25, 2015 03:51 PM
