T56 pops out of gear
Old Nov 7, 2001 | 04:44 PM
mrls199's Avatar
I've been having a problem lately with my T56 in my 99Z28 popping out of 2nd and 4th gear and i can't get them to engage. I am thinking it might be a shifter problem because you can see and feel that its not going all the way in the gate.
I have a B&M ripper, I am using the stop screws (the rear one might be too far in or something) and i used the washers to offset it towards the driver. I plan on doing a reinstall soon using new bolts, a new bushing, and the standard washers. What could be causing a problem like this?
any help appreciated, shoot me an email: bradwhite_79@hotmail.com
Old Nov 7, 2001 | 05:56 PM
SLAYER6669's Avatar
Car: 1991 Camaro Z28
Transmission: T56 6-Speed
I'm interested in this as well, my shifter pops out of 3rd gear ALL the time.. at least a few times on a say 15-20 minute city drive.. It happens right after I put it in gear then let off the clutch and its gets more annoying every day.. I'm just afraid my first time to the track with the 6 speed I'm going to end up poping out of 3rd and revving real high and ruining my engine.. I also have a problem where I can't downshift 6th to 5th, which isn't really a big deal beacuse I don't really hit 6th that often.. I am assuming its just the synchros for that problem..
1991 Camaro Z28
CURRENT MODS:
350 TPI, T56 6-Speed, Edelbrock Headers, Edelbrock Runners, Edelbrock Intake, Flowmaster Exhaust w/ Flowtech Cutout, MSD 8.5mm wires, Autolite Double Platinum Plugs, MSD Cap/Rotar, Random Technology high flow cat, Hypertech Power Chip (160 Deg Thermo), K&N Filterchargers
STEREO MODS:
Pioneer DEH-P6000, 2 JL Audio 12W3 subwoofers in custom hatch enclosure,
Rockford BD1000.1 Amp, Infinity Kappa 4x6" plates & 6x9's
WEBMASTER: www.thirdgenfbodies.com
Old Nov 7, 2001 | 07:22 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
My T5 does this in first gear and I have been told it may be worn shift forks or bad synchronyzers.
Old Nov 7, 2001 | 10:13 PM
JosephSDSC's Avatar
I wouldn't use the Shifter stop bolts at all, they aren't needed on the T56. The T56 has its own built-in shifter stops. Now on the 3rd gear popping out on Decel, there is a TSB on that. I've been replacing the 3-4 shift fork, 3-4 syncronizer, 3+4 blocking rings. At the same time I usually do the same things for 1-2 gears if it seems necessary.
...Joseph
ASE Master Technician
Scoggin-Dickey Chevrolet
Project 67 Camaro
Old Nov 7, 2001 | 11:17 PM
mrls199's Avatar
Joe, you got it right... i pulled the console and boot tonight and i found the rear stop bolt was keeping me from engaging 2nd 4th and 6th gear... removed them, went for a test drive. Now if i could just get it to be quieter...
billybob6110
Feb 11, 2016 10:41 AM
IROCtometal
Sep 20, 2015 11:08 PM
19irocz85
Aug 26, 2015 07:54 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
