87 t5 into an 84 car?
Old Jul 27, 2009 | 05:43 PM
S10GUY's Avatar
Car: VR6 jetta for commuting
Engine: VR6
Transmission: 5spd ZF lsd
Axle/Gears: ?
i have a auto 84 Z/28 and I found a 87 5spd z/28 for parts. can i use all the 87 parts in my 84? will the center consel pedals etc. carry over also. thanks
Old Jul 28, 2009 | 05:35 PM
S10GUY's Avatar
Engine: VR6
Axle/Gears: ?
Re: 87 t5 into an 84 car?
the guy with this car emailed me back today said i could have every part i need for the conversion for $200, i gotta pull it myself. anyone no if the 87 parts will work in my 84?
Old Jul 28, 2009 | 05:57 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
yes they should all fit. you should take the trans crossmember as well, i know the early cars had different ones because of the 200r4 and t10, not sure what you have.
everything else will bolt in, you will need everything you can get, pedals, hydraulics, the trans, wiring pigtails, the shifterplate my be different, im not sure. You can grab the flywheel and clutch, but probably want to get new ones as well.
for a better list, look for the article in the tech section on the homepage, there is a pretty good list there.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
