tranny leaking bad when engine shut off
Old Jul 28, 2009 | 06:29 PM
pgilla1's Avatar
Car: 91 camaro rs blue with black stripe
Engine: 5.0 in car 5.7 in garage
i replaced my 91 camaro 700r tranny with a 700r from a 90's model truck i had to swap tail housing and gears from the shaft. i also replaced the front seal. i filled it up with fluid andtest drove it everything was fine when i parked the car with the engine running tranny fluid started running out like a water fall. i jacked the car back up to make sure the lines were tight and to see were the leak was coming from i could not tell. i started the car while it was jacked up and nothing happened i let it run for about 30 minutes and no problem, i let teh car down and test drove it noticed smoke coming from under d car i parked the car and look under it there was a small leak no big deal i thought i turned the car off and just like before fluid coming out like a water fall.. any suggestions would be appreciated
Reddeath210
Oct 6, 2015 08:20 AM
wayshegoes
Aug 17, 2015 12:00 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
drathaar907
Aug 6, 2015 04:20 PM
