lookin to get a used posi...?'s about it
im hopefully goin to get a used posi unit out of a 10 bolt rear from a firebird i believe not sure. but the guy thats saling it is sellin it on this site and he said it has less that 100,000 miles on it but taken good care of and well maintained. also he said it worked good when he took it out. now does anyone think i will have a problem puttin it into my 10bolt rear in my 82 z28, and do u guys think its a good deal for it goin for $50 i believe. so any comments are helpful thanx
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Temp,
Thats not true i put a zexel torsion posi in a 3:73 rear i got. All i did was take out the carrier, press new bearings on and set it up to the same specs that the old carrier was. It took a few hours (checking everything twice) I have been driving it for ~5000 miles and i have had no problems. Its when you mess with the pinion that i would recomend a shop.
Hey, 1982chevycamaroz28
Buy the posi
Buy the posi
hey i wil do and buy it becuz im not goin to pass up on a deal this good. also would i need to take it to a professonal to get it put in so like i dont screw things up, which i dont want to happen. thanx
also aboutthe posi its a 2 carrier im remembeering and also it came out of a 89 formula, they guy told me it has the 26 spline axels so it should bolt right up to my axels.
I ROCK
Dec 18, 2000 01:37 AM
I ROCK
Dec 18, 2000 01:24 AM
