Mini spool.. whining noise
Alright so i just bought a complete rear the other day.. used to have 2.73:1 open stock 6 cyl rear.. 7.5 inch... new rear is all the same size just with richmond gears, mini-spool. when im cruising between 20 and 60 and let off the gas i get a whining noise.. i assume the backlash on the gears is not adjusted properly. but i just wanted to see if anyone has experienced any similar problems with a rear. and what kind of problems might come if i drive on it for a couple days
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Mini spool.. whining noise
Mini spool has nothing to do with gear noise Any noise would be related to the gear wear pattern.
yes i know this... my question was if people experienced noise from the rear diff. and if driving on it cause problems.. i think the backlash is too tight but i wont be able to reshim it for about a week when i have off again
Car: 87 IROC L98
You said it used to have 2.73 gears so I'm assuming a gear change was also done. Pinion depth could also be wrong. Did you take the shims from behind the pinion bearing on the 2.73 pinion and put them behind the bearing for the new set?
Did you even check the gear pattern when it was assembled?
If you just bought this rear end, was it used or just rebuilt? If it doesn't have any miles on it yet then fix it NOW. If it was used when you bought it then it's too late to do anything about it now. Get some ear plugs or a louder sterio.
Car: 87 IROC L98
It depends on the wear pattern. Adjusting backlash is only part of setting up the gears. If you set the backlash to within limits, it won't fix an improperly installed pinion depth.
Car: 90 camaro
Engine: 355
Transmission: t10
Axle/Gears: 9" with 4.88's
most likly the gears are shot if they were set up wrong and ran any amount of time. If gears are set up wrong and ran they will wear improperly and turn them into junk.
sjorgens
Oct 1, 2015 07:54 PM
