LT1 swap... should i use the 700r4 or the 4l60e that comes with it
Old Jul 27, 2009 | 10:15 PM
kukerdan's Avatar
Hi,
I bought a 96 impala ss motor and tranny, still bolted together, full swap.
I have a built up 700r4 or 4l60 in there now, but its v6..
I would rather keep my tranny if I can just put a v8 shroud on there..
will the one from the 4l60e work?
Or should I just go 4l60e with 78k on it
Dan
Old Jul 28, 2009 | 04:33 PM
transtalker's Avatar
Car: 95 Suburban K1500
Engine: 355 TBI,heads,cam,flowmaster exhaus
Transmission: 4L60E custom rebuild, mod shift kit
Axle/Gears: 3.08 front and rear
Re: LT1 swap... should i use the 700r4 or the 4l60e that comes with it
the 4l60e would require wiring harness and computer all to be swapped but your 700 will not bolt up to the v8 if it was behind a 2.8 and they dont make an adapter plate to go from that bolt pattern to the v8 my opinion you need to get a 700 that has proper bolt pattern
Old Jul 28, 2009 | 09:53 PM
85camarojunkie's Avatar
Car: Camaro coupe
whats wrong with the trans that is bolted to the motor from the SS.
Old Jul 28, 2009 | 10:29 PM
bmfIROC-Z's Avatar
what he^ said,if the 4l60e is good use it,it'll be alot easier,i know from experience.
Old Jul 28, 2009 | 11:09 PM
Car: Camaro coupe
the 4l60e is much more electoniclly anvanced than the 700. The 700only uses a plug to lock up converter. were as (corect me if im wrong) is running off the computer constantly with the motor. Its confusing but just stick with the one bolted to the motor.
Old Jul 29, 2009 | 11:08 AM
kukerdan's Avatar
that makes sense...
I wanted to use my 700 because its fresh, and built up.
maybe 10k miles verses 78k on the 4l60e bolted to the motor.
I know I would need the bellhousing , a new torque converter, and a 93 lt1 throttle body.
When the shipped me my trans, it had the wrong bellhousing on it, and my mechanic used the one off my stock 700r4,
I thought this meant they shipped me the 90 * v8 vs the 60* v6, and I thought just this peice was needed to go between...
Anyone have experiance with 96 impala SS?
How do they shift?
Old Jul 29, 2009 | 11:28 AM
Car: Camaro coupe
?? bellhousings on autos cant be changed...
Old Jul 29, 2009 | 11:37 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
What he said. The bellhousing is cast into the case on a 700r4, not a separate piece like on a T5 or T56. From the two transmissions you have, the 4L60E is your only choice.
Old Jul 29, 2009 | 12:00 PM
kukerdan's Avatar
hmm allright
I guess Ill run it till I blow it, and throw a worked one in when that day comes.
thanks
anyone interested in the 700r4 for the v6 ? shfit kit / corvete servo/ boost valve. kevlar bands/ etc etc.
Old Jul 29, 2009 | 01:11 PM
Car: Camaro coupe
does a corvette stall fit in a 60* trans??? I thought the bellhousing was to small for a 90*converter. Thats new for me.
Old Jul 31, 2009 | 10:15 AM
kukerdan's Avatar
Ok, I guess I am going to use the 4l60e..
Is my speedo going to be plug and play with this?
Ive read posts on here saying it worked no problem with stock VSS, and others saying no go.
Also, will my stock shifter work for this tranny? its out of a floor shifted impala ss, so I need new cable / linkage ?
Any advice?
thanks
Old Jul 31, 2009 | 05:25 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
700R4's are pretty much junk if you plan on putting any kind of real power through them.
bigjay89gta
Oct 15, 2015 08:04 AM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
Gordonr1973
Sep 29, 2015 11:59 AM
6998poncho
Sep 25, 2015 02:56 PM
