hey guys
Car: 1985 firebird
Engine: chevy 350
Axle/Gears: soon 3.73
hey guys
im new on here but i will b here for a while i think lol. i also might sound dumb but i have an 85 firebird and i was needing to know what the bracket that hooks to the rear of the transmission it has some kind of support on the rear end.
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: hey guys
Since you're new, some pointers before going on..
- Put your question in the subject. Very few people with bother reading a thread "Hey Guys"
- Put your detail in the first sentence. Rolling over the Subject in the list will pop up the first sentence, again drawing in the folks that can help you.
- Since you may not know the correct terms for the items you have questions about, try to describe them so a blind man can see them in his mind.
- Fill out your profile with your location, your car/year/motor/trans/rear-end/etc. Otherwise, Most every response back will be "What _____ do you have?"
Now here goes.. You mention a bracket, which may be the simple support that the catylitic converter mounts too in stock exhaust setup. But you also mention the rear end, which may describe the torque-arm, which is a suspension device that limits the rotation of the rear differential by place the moment-of-center at the rear of the transmission through a (stock) rubber mount.
So if either of those help you, you can proceed and follow up with any questions you have about the exhaust/Cat. hanger, or the Torque-Arm (TA).
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: hey guys
sounds like you are referring to the torque arm, and no you cant get rid of it.
what are you looking to do?
Car: 1985 firebird
Engine: chevy 350
Re: hey guys
it is the torque arm u mention and it hooks up to the transmission right? i am sorry about the newbie mistakes i will now know. so would it be called the TA bracket? if so where could i perhaps find one? and i thank u for all of the advice
Car: 89 RS
Engine: 305 TBI (lo3)
Axle/Gears: Whatever is stock.
Re: hey guys
I have a 89 rs camaro I am parting. The trans is gone along with the bracket for the ta. I still have the ta, & the bracket for the rear, but I havent looked to see if the rear is welded to the diff. We need to get the info from you in order to know just what your wanting. If I have what you need then let me know. If not then It should be easy to find on this site.
Car: 1985 firebird
Engine: chevy 350
Re: hey guys
all i need is the bracket i have the TA. And maybe hardware if u have it if not i can find it im sure. and do u know how i can get my exaust up off the ground it sits low and it bottoms out on every little thing so let me know. thanks for the help.
Car: 89 RS
Re: hey guys
I will take a look tomorrow and see if I have the bracket you are looking for.
Car: 1985 firebird
Engine: chevy 350
Re: hey guys
yes its the bracket that hooks the TA to the trans. and on the exaust its ok i am going to have duals ran on it anyways with 40 series flowmaster so when i take it in i will ask them if they can get it sucked up a bit. thanks alot for ur time.
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
