2nd gear chirps???
Old Nov 6, 2001 | 12:24 AM
daryl's Avatar
2nd gear chirps???
anyone able to break tires loose hitting second with a 700R4 and bw 2.77 rear?? if so, what kit and upgrades are you using?
Old Nov 6, 2001 | 01:07 AM
Pro Built Automatics's Avatar
With 2.77's, I would not even try for 2nd gaer rubber. Just go with the best kit (no matter what gears are in the rear) the Trans-Go Performance Shift kit & related parts, you will not go wrong doing this. This kit still will give firm shifts, if everything in the trans is still in good condition.
Old Nov 6, 2001 | 01:46 AM
CHVYPWR's Avatar
Car: 1978 El Camino SS
Transmission: T-5 & 3.73's
My cousins 'Bird grabs 2nd without even trying! Heres the info from his sig.-
-'91 firebird
305 TBI
Hypertech chip-thermomaster
Edelbrock performer intake
Crane compucam 2010
B&M shift kit
straight pipe exhaust-with resonator tips
160 thermostat
open element
He's on this forum with the name stormr.
Ya can't have too many fast Chevys!
Old Nov 6, 2001 | 03:44 AM
transfixleo's Avatar
I agree with Pro on this. The time measured in revolutions of the driveshaft is allot longer than, lets say a 3.73, which would be very easy to achieve the 'tire chirp' you are after. Just about the only way is with a Bang type kit set on kill, such as the B&M Non-shift-kit, and a non-Posi with narrow tires. IF you get what you are after, start setting money aside every week in your rebuild-my-tranny fund as parts can be expected to break.
Old Nov 7, 2001 | 10:28 PM
Black82Z's Avatar
I have the B&M trans pak , and it is set on kill. I can bark them with 3.42's in the rear with a posi and 255/60 bfg radial ta's. It hits hard and i am waiting for something to break, again. I already shattered the spider gears in my last rearend.
82 Z28 have LG4-305"
Rebuilt heads-3 angle valve job,ported and gasket matched. comp cam xtreme energy 262 edelbrock performer, chevy 1.6:1 roller rockers,MSD6AL, rebuilt carb,15x4" K&N
3"flowmaster american thunder, Mac high flow cat,headman headers,
700-R4--B&M shift kit, B&M tranny cooler.
Sub-frame connectors, boxed lower control arms and torque arm. 1.5" front sway bar, new BFgoodrich radial T/A's--215/65 front 255/60 rear
RADIO-- premier Deh-p300
2-10"kicker SPLs,ZR240,premier 434x(4 way), custom built fiberglass box for subs. pioneer 6X9 & 4X6, grant GT steering wheel
Old Nov 8, 2001 | 02:26 PM
With 3.42's it is easier to do. Even more so with 3.73's.
Old Nov 8, 2001 | 09:37 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I have the Transpak and it shifts pretty firm even under light throttle. It has something in there that knows where you have the shifter. If I have it in "OD", then it's a firm shift, but not harsh. But if I have it in "Drive", it about jerks my head into the seat, and that's under light throttle. When I nail the throttle it just skwalls the heck outta that peg leg rear end going from 1st-2nd.
I like it. I ain't worried about what it does to the spider gears 'cause I'm gonna get one of the Power Trax lockers eventually anyway.
BTW, I have the 2.73 gears. It was only $65 for the kit and it doesn't bother me if it breaks something. Just gives me an excuse to R&R. But I wouldn't recommend it for someone who's looking to spend a small amount of mula because yer gonna have to replace something eventually.
AJ
92 RS w/t-tops 305 TBI Auto.
175K miles and don't burn a drop o'oil
-K&N Truck filter #1500 w, open ele.
air cleaner
-Dynomax 2 1/2" cat-back
-B&M TransPak
-Jet Stage2 Chip
-180* T-Stat w/ 185* Fan Switch
-JVC CD--Alpine speakers & 4ch. amp
Rockford Punch 100. 1 - MTX 12" sub
Old Nov 10, 2001 | 06:00 PM
u r sofa king we tah did's Avatar
my L98 with 2.77s will spin the tires during the 1-2 shift. its a dying transmission with a cheap self installed B&M shift kit. you can hear the tires chirp on the 1-2 shift on dry pavement at 3/4 throttle, but at WOT the engine and exaust is too loud to hear it.
Old Nov 10, 2001 | 06:21 PM
bottlefed89's Avatar
tire chirp and being able to break a tire loose are two different things which are you talkin about?
Black 89 5.7 355 cu
Performance transmissions 700R4
black and flamed to the taillights, much much more....
Old Nov 10, 2001 | 07:30 PM
Joshua Leslie's Avatar
I can chirp them on 1-2, and on 2-3, I have the 2.73 rear end.
300h.p. and a race built trans.
Old Nov 10, 2001 | 09:12 PM
89formula350tpi's Avatar
Car: 1989 Firebird Formula
Engine: 350 tpi
I have a bw with 2.77's in my 89 formula 350 and I can break em loose pretty good and even get my car to pull a little sideways in second. My motor is bored .40 over with crane cam, hooker headers, hypertech chip, afpr, k&n, and ported plenum.
Old Nov 11, 2001 | 05:14 PM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
Mine will break loose going into second and chirp 'em going into third with a 3-speed Turbo-350 and 2.73's. Rest of mods are in the sig. It's really fun it holds the 1-2 shift at 4500-5000 for like three seconds before it shifts and I get sideways going 50. Okay maybe a little scarier than fun. But definatly cool when you leave school!
-Matt
1984 Camaro Z28 - Black w/ Grey int.
-GM Goodwrench 350 with Edelbrock 600 Carb, Edelbrock Preformer RPM intake, AC Delco plugs, 8mm AC Delco wires, 14" Accel filter, Homemade Cold Air Indctn., Edelbrock Chrome valve covers, breather, and Air cleaner.
- Profesionally Built Turbo-350 with 2500 RPM Stall converter, Hurst shifter, & one wicked shift kit.
- Eagle Alloys 15" Alum. Rims surrounded by P235/60R15 BF Goodrich Radial T/A's
-Comming Soon:
3.73's, MAC Cat-Back, hollowed cat., B&M Megashifter, & Paint: Navy Blue Metallic w/ Silver strips
Pics at: http://members.fbody.com/flashz28/
db057
Apr 28, 2019 07:45 AM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
88rscamar0
Sep 23, 2015 09:08 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
