Tranny is slipping on takeoff
Old Nov 12, 2001 | 09:22 AM
Trent257's Avatar
fluid is full, its on a 90 firebird v6 auto
is the tranny going?
Trent
---Car---
89 Firebird/305 L03 TBI A4/t-tops
Open Element Edelbrock Aircleaner w/ K&N air filter/Summit Chrome Valve Covers
Edelbrock TES headers 3" out/flowmaster American thunder 3" exaust/Catco cat
---Stero---
Pioneer DEH-P730 Premium
Infinity 2way 4652 4x6's/Pioneer 4way ts-a6985 6x9's
profile cl640 110x4
Old Nov 12, 2001 | 09:57 AM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
A strong posibility. Is the fluid burnt? My buddy had an 82 with tht clutch type converter. Is sounded like it was slipping when it really was not.
Old Nov 13, 2001 | 04:24 AM
transfixleo's Avatar
Most likely, from what you've told us. Does it do it in Reverse too? When you do drive it, if you give it more gas do the shifts get later/firmer? You might want to try this: To adjust the TV Cable skip the book method and do this: Press the D button on the adjuster and loosen the cable setting. Now, have someone floor the gas pedal while you check to see if the throttle plate is open all the way. Usually they are off a little and will wiggle. Do whatever you have to do to get it open solid. Now, with the pedal still floored, press the D button and pull the cable casing (the black tube) back as hard as you can and release the button. You now have the engine, tranny and gas pedal all in sync at WOT. Mark the cable so if for some reason it gets moved you can know where to put it again. The problem with the 'self adjust method' is that it bends things and puts them permanently out of whack. It is also the full TV setting, which is theoretically what the GM method does.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
jrdturbo
Mar 31, 2016 02:58 PM
bjpotter
Oct 4, 2015 07:48 PM
mfp189
Sep 27, 2015 09:25 AM
IROCZ1989
Sep 4, 2015 11:54 AM
