28 spline axle?'s
Old Nov 13, 2001 | 02:00 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
28 spline axle?'s
hey guys, i have a 1986 drum posi rear with 3.23's i'm going to be putting a new posi carrier and 3.73's in but the new carrier is 28 spline axles, and my old 26 spline axles are toast due to worn bearings, what year rears can i get 28 spline axles out of? is there a difference in drum vs. disc? also do you know what speedo gears i need to change to? it's a T5, 10 bolt 7.5 drum setup
Old Nov 13, 2001 | 02:10 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
I believe it's '89 and up that have the 28
spline axles. The disc rear ends are totaly
different BW 9 bolts. My '88 has 26 spline axles.
Old Nov 13, 2001 | 07:16 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
89 is a crossover year. most were still 26 spline. You want to find a 90-92.
You can also buy better aftermarket 28 spline axles from places like www.drivetraindirect.com for $125 each. The aftermarket ones fit drum or disk. I don't know about factory axles.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
cheesehomer
Dec 31, 2015 08:48 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
usafirebird
Sep 29, 2015 11:58 PM
Prodigious
Sep 18, 2015 05:23 AM
rudolphschenker
Sep 4, 2015 02:41 AM
