700r4 servo replacement
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
does anyone know if there is room to swap out the servo on these cars without dropping the crossmember.
Car: 86 Z28
Axle/Gears: 3.42 posi
Re: 700r4 servo replacement
yeah i just did that when i installed my shift kit from pro built. You just have to remove them from the shaft one by one to get them out.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
if you can unbolt the crossmember and lower the tail end of the trans a little, watch you dont break the dizzy cap, it will give you a little more room to work.
Or, IIRC when i swapped mine a few years ago, i left the crossmember alone, removed the trans mount and let the trans drop that extra couple inches, pushed it over to the driverside of the tunnel and had enough room to work.
Car: 1988 iroc-z
i have to be carefull about lowering the trans, i put the motor trans and rear all in my self,and i took it to the exhaust shop .the exhaust is ONE piece from the headers back ,all welded! i had the down pipes welded to the headers........ i cant stand exhaust leaks.so if i can sneak it out without touching the crossmember thats great.if not, i have to lower the whole exhaust.
Car: '85 IrocZ
I have this EXACT same question haha! I tried removing the single stud/nut from the trans mount and tried to push the trans over....its not budging so I'm going to try and wedge it.
Otherwise I'll try the removing bracket and lowering the trans technique. Will that work even with the torque converter all bolted up the motor?
Thornburg
Aug 25, 2015 01:46 AM
