stong 10bolt buildup
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
i want to keep the stock rear end....
now, should i get some moser axles, and a thicker pumpkin housing and rear cover?
who says 7.5" 10bolts can't handle power!
I have seen a 10 bolt, 7.5" camaro run 11's. It had an aluminum cover, GM 4.10 gears, and an auburn posi unit. I had to see it to believe it!
86 Iroc, 355 ci, Dart II heads, holley 750, Victor Jr., Hooker super comp headers, 4.10 rearend, MSD 6A, roller valve train, high stall converter, true dual flowmaster exhaust, NOS- 150 shot.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Mine is still holding up after being built up. Just follow the "10 bolt build up" article. If you can get a 28 spline carrier (SLP Torsen etc) you can get good 28 spline axles from www.drivetraindirect.com for $125 each.
They don't make c-clip eliminators for the 7.5" 10 bolt. Aftermarket axles and "axle-retention device" are manditory for cars running 10.99 and quicker. Rear disk brakes qualify as axle-retention devices. If the c-clip breaks off the axle still can't come out because of the caliper holding the axle in.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.586
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
Do you guys recommend the Auburn posi or powertrax or anything else?
84 Z28 L69. 5 speed with 3.73 posi (broken)Ported heads, intake, 10:1 comp. 230/230 .480 lift cam @.050"
unknown_host
Aftermarket Product Review
59
Sep 3, 2001 10:59 PM
sharky55
Aug 2, 2001 04:17 PM
scottmoyer
Jun 12, 2001 02:45 PM
